Why I can't change the TX power of devo7e ?
- Scccc
- Topic Author
24 Sep 2017 02:58 - 24 Sep 2017 13:31 #64616
by Scccc
Why I can't change the TX power of devo7e ? was created by Scccc
I have been shorting resistance successfully. And I Changed the MCU to 256kb . But in the firmware(night building devo7e 256) of devo 7e 256 from night building can not change the power of transmitter it shows "default" . I need modify the "hardware ini "?What should do ?
Last edit: 24 Sep 2017 13:31 by Scccc. Reason: More clearly reason
24 Sep 2017 15:20 #64623
Replied by mwm on topic Why I can't change the TX power of devo7e ?
I don't think the CYRF6936 in the 7E has a power amplifier in it, and that's the hardware that is used to change the power level. You can enable changing it in the software by setting has_pa-cy4f6936 to 1 in hardware.ini. But if there isn't one in the radio, changing the power levels in the settings won't do anything.
- Scccc
- Topic Author
25 Sep 2017 14:50 #64659
by Scccc
Replied by Scccc on topic Why I can't change the TX power of devo7e ?
Thank for your help ,now I can change the transmit power from 100uw to 150mw. Thank you so much.
Time to create page: 0.025 seconds
- Home
- General
- General Discussions
- Why I can't change the TX power of devo7e ?
