JUMPER T8SG My problem.
07 Nov 2017 06:40 - 25 Dec 2017 06:14 #65599 by daive
JUMPER T8SG My problem. was created by daive
RCヘリ&ドローン のんびり飛行:マルチプロトコル送信機 Jumper T8SG
日本語翻訳がありました。全文かどうかは、未確認です。
blogs.yahoo.co.jp/sab_goblin/42797398.html
blogs.yahoo.co.jp/sab_goblin/42797407.html
T8SG is my Epoch-making Transceiver.
But there are several problems.
If what kind of information is taken out, is help obtained?
All items were bought in 2017/AUG-2017/NOV.The date of production is unclear.
(transrated : www.excite.co.jp/world/english/ )
0. Jumper T8SG : t8sg-v5.x.x-2017-10-05 , lastest version ?
→vlad_vy replied the topic: Jumper T8SG builds www.deviationtx.com/forum/builds/7346-ju...uilds?start=80#65802
2017-12-18版 :https://www.deviationtx.com/downloads-new/category/829-2017-12-18
ファイル名  :deviation-t8sg-v5.0.0-4810939.zip
 Manual : download.appinthestore.com.s3.amazonaws....%20User%20Manual.pdf
 The Japanese user is waiting for Japanese radio law correspondence. ((((oノ´3`)ノ
↓↓ TARANIS Q X7 & iRX4 Plus Can be used . (14-DEC-2017)↓↓
1. JJR/C H36 , Protocol : MJXq / E010,Tx power 30mw-100uW, It can't be bind. , Even if it can be bind, no control.
→ E011 and E010 with Multiprotocol T8SG :https://www.deviationtx.com/forum/6-general-discussions/7397-e011-and-e010-with-multiprotocol-t8sg#65424
 E010 latency with T8SG : www.deviationtx.com/forum/6-general-disc...ency-with-t8sg#65539
 more.
'(EDIT:13/NOV/2017)
 プロトコル変更で融通きかなくなった6mmモーター系 : jizomae.blog.jp/archives/73428370.html
→ My fuselage was bought from amazon.co.jp. 0615 motor ToyQuad is very inexpensive.
  jjrc h36 mjxq e010 protocol bind problems
   www.deviationtx.com/forum/protocol-devel...otocol-bind-problems
↑↑ TARANIS Q X7 & iRX4 Plus Can be used . (14-DEC-2017)↑↑
2.Cheerson CX-10SE:BLACK , Protocol : CX10 / Blue-A , Tx pw : 10mW, No problem. , A BLACK orginal-controller can't be used by ivory.
3.Cheerson CX-10SE:IVORY WHITE , Protocol : CX10 / Blue-A & Green & other , Tx pw : 10mW, It can't be bind., A ivory orginal-controller can't be used by Black
4.Floureon F10 WHITE , Protocol : H8-3D / H8-3D , Tx pw : 10mW , No problem.
5.Floureon F10 BLUE , Protocol : H8-3D / H8-3D , Tx pw : 10mW , No problem .
6.JJR/C H20 , Protocol : H8-3D / H8-3D , Tx pw : 10mW , No problem .
7.JJR/C H20H , Protocol : H8-3D / H20H , Tx pw : 10mW , It can be bind. but , propeller Starting method is unclear.
 Altitude Hold Mode Quad , H20H controller : propeller starting , A throttle is pushed. Takeoff , throttle up.
⇒Select ʺH20Hʺ format, CH5 = motors on/off:https://docs.google.com/spreadsheets/d/1nBHzT3VWF6ShAhOqRB5y0Bcc7aXFuRFFlQkHn1RIM84/edit#gid=0
( 09/NOV/2017 , for DEVO )
8.Eachine E012 , It isn't being checked in T8SG.
→ EAchine E012 :https://www.deviationtx.com/forum/protocol-development/7150-eachine-e012?limitstart=0
9.FuriBee F36 , It isn't being checked in T8SG. , F36 / T36 can share a controller.
10.GoolRC T36(TOMTOP T36) , It isn't being checked in T8SG. , F36 / T36 can share a controller.
→ Furibee F36 protocol attempt :https://www.deviationtx.com/forum/protocol-development/6806-furibee-f36-protocol-attempt?limitstart=0
11.HELIWAY 901HS , It isn't being checked in T8SG. , throttle nutral by a spring. ,can share a controller. I have that checking ly.
 Altitude Hold Mode Quad , 901HS controller : propeller starting , Left:Bottom Left corner & Right:Bottom right corner. Takeoff , takeoff button.
12.HELIWAY 901S , It isn't being checked in T8SG. ,can share a controller. no nutral spring.I have that checking ly.
※DBPOWER 901HS doesn't have it, so it's unclear. Holy Stone HS190 / HS190W look like HELIWAY 190S / 190HS.
 SHIRUI 901HS = HELIWAY 901HS.
 DBPOWER 901HS : www.amazon.co.jp & www.mercari.com/jp/ , no camera , no wifi fpv , Altitude Hold Mode (13/NOV/2017)
13.FDJ Z201YS , It isn't being checked in T8SG.
20. S9 Micro Foldable RC Drone , It isn't being checked in T8SG.
   STANDARD : No Altitude Hold Mode.
   Wifi FPV : Altitude Hold Mode Quad
14.FQ777 124 , Protocol : FQ777 / 124 SSV , Tx pw : 10mW , can share a controller. I have that checking ly.
15.FQ777 124+ , Protocol : FQ777 / 124 SSV , Tx pw : 10mW ,can share a controller. but,124+ battery exchange can be done, so it's thick.I have that checking ly.
16.HT F807 , It isn't being checked in T8SG.
17.Cheerson CX-37 ( CX- 37WD ), It isn't being checked in T8SG. , CX-37-TX controller can be bind.
18.Cheerson CX-37-TX ( CX-37WD-TX ), It isn't being checked in T8SG.
19.Cheerson CX-STARS / DHD D1 , It isn't being checked in T8SG.
  DRONE D1 / PXY nano / Fayee FY804 / SKEYE Pico , same ?
  Floureon FX10 ?
21.JJRC H67 , Protocol : Bayang , Tx pw : 10mW , can share a controller, RED / WHITE . I have that checking ly.
0716 motor, 3.7V / 260mAh / 30C lipo , (^◇^)
  H67 / E011 / E011C : Look like same.
1 / 9 / 10 / 21 : Propeller look like same.
2 / 3 / 4 / 5 / 14 / 15 :Propeller look like same.
2 / 3 / 4 / 5    :Propeller guard look like same. insertion hole : Cross hole
6 / 7       :Propeller look like same : 2 / 3 / 4 / 5 / 14 / 15
14 / 15      :Propeller guard look laike same. It's difficult to load and it comes off right now.
11 / 12 / 13 / 20 : Propeller , Propeller guard , look like same.
17 / 18     :Propeller , It's a little shorter than 11 / 12 / 13 /20
Seller,found only here? : www.linparts.com/cheerson-cx37tx-mini-rc...c454bc8#.WhQG0eRlJ9A
Betaflight & F3 FC & DSM2/DSMX
Min / Max Limit が±120でも、Scale - / + が100 だと、スティックの値がフルスケールで反映されないので、
この場合は、(スロットルの例です。この設定をしないと、モーターの起動/停止が出来ない。 )
Model menu:Mixer:1-TR:Min Limit -120 / Max Limit 120
Model menu:Mixer:1-TR:Scale- / Scale+ : 100   <<これが100だと✖
Model menu:Mixer:1-TR:Scale- / Scale+ : 120   <<これが120だと〇
としてみる。私の処は、150 / 100 だったので、150 / 150 としました。
aurora68+deviation:マイクロヘリABC:http://cyuryo.cocolog-nifty.com/blog/2017/05/aurora68deviati.html
2.2 Scaleの設定
に、記述があります。「マイクロヘリABC」さんに感謝(^^♪(2017-DEC-25)
他に、BF:CLIでの DSM2/DSMX バインド方法の例があります。
Last edit: 25 Dec 2017 06:14 by daive.
09 Nov 2017 13:05 - 09 Nov 2017 13:14 #65654 by daive
Replied by daive on topic JUMPER T8SG My problem.
以下は、テスト投稿用の文面なので、鵜呑みにしないように御願いします。
<<日本語での、投稿テスト>>
私の母国語は、日本語なので、
投稿の度に、翻訳サイトの世話になるのは、面倒だ。
だが、私の英語レベルは、技術書を読むには、困らないが、
意思疎通手段としての、英語は、赤ちゃんレベル以下だ。
母国語が使えれば、楽ができる。
仕事しながら、ボチボチやるので、更新、検証には時間がかかると思う。
T8SGは、Deviation済みとは云っても、ファームの更新やらで、
開発環境は、必要な筈だと思うので、
挫折しなければ、次の順にやって行こうと思います。
【やることリスト】 :可能であれば (^_-)-☆
1.機材の確認。
  PC:Windows 7 / 8.1 / 10 , x86 , x64 どれが使える?
  MCU相手になるので、
  秋月電子、RS-ONLINE、Digikey、Mouser辺りで
  手に入る物かどうかの確認。
2.開発環境のインストールと方法の検証。
3.オリジナルファームウェアのバックアップ、リストア
4.ファームウェアの更新
5.手持ちの、トイクワッドでの、T8SGでのバインド方法
誰か、英語版取説を、日本語にしてくれないかなぁ。
⇒お前がやれって、云うのは無しで ( ^^) _U~~
日本語でのテスト投稿了
Last edit: 09 Nov 2017 13:14 by daive.
10 Nov 2017 07:49 #65695 by dc59
Replied by dc59 on topic JUMPER T8SG My problem.
Thanks for sharing your test result.
13 Nov 2017 02:31 - 15 Nov 2017 12:01 #65778 by daive
Transrate : www.excite.co.jp/world/english/
1.先ずは、取説読む、英語で解んね~なんて云わないで !(^^)! (誰かが翻訳してくれるまではねぇ。翻訳が下手だと、英語の方が良いかも。)
  で、私に聞いても無駄です。T8SGについては、貴方と同じくらい初心者です。
2.←:Getting Started :T8SG ユーザーは、殆ど済。幸いなるかな。
3.←:FAQ :大切だが、活用されない事も多い。
4.T8SG = DEVO 7E + 4 in 1 transmitter ?
  引用サイト例、Quotation site example:https://blog.okamoto.ws/2017/08/deviationjumper-t8sg.html
  Original Source : Jumper T8SG - First TX stock running on Deviation : www.deviationtx.com/forum/6-general-disc...new-tx-from-banggood
5.使用する機材
 5-1.T8SG : Gearbest購入、USBは、mini-usb、
 5-2.Lipo:ZOP Power 7.4V 2200mAh 8C 2S Lipo Battery JR JST FUBEBA Plug for Transmitter:banggood
 5-3.ノートパソコン:ENVY 17 , Core i7-4700MQ 、16G-RAM
   OS: Windows 10 x64 Pro, Creaters update.
     Windows 8.1 x64 Pro
     Windows 7 x64 Pro
     マルチインストール、
     x32(x86)は、Windows 7 の遅いのしかないなぁ、MouseComputer:LB-L300
 5-4.USBケーブル:mini USB 、有り合わせの物
 5-5. MCU tools
  F103 evaluation board、ST-LINK も有った筈。( ..)φ memo , memo
  Devo 7E Hardware Connections : www.deviationtx.com/wiki/hardware/devo7e
   MCU : STM32F103RBT6 , GPIO : USB , SPI , USART , etc
   STM32 Nuclieo Board STM32F103 : evealuation board で使える物が、使用可能か?
    STM32 Nuclieo Board STM32F103 : akizukidenshi.com/catalog/g/gM-07724/
    STM8 / 32 プログラマー ST-LINK V2 : akizukidenshi.com/catalog/g/gM-04012/
  →F103 , ST-LINK の所在確認する。
6.ダウンロードするもの
  ←Downloads:https://www.deviationtx.com/downloads-new
  詳細は、後ほど。
 6-1.その前に、HDD/SDD の完全バックアップを取る事。
   True Image etc. back up tool を使って、HDD / SSD の完全なバックアップを作って下さい。
   理由:開発ツール類は、Ver / Edition によって不完全で、PCの環境を破壊する場合があります。
      また、アンインストールするのに、Uninstaller (ex.IObit Uninstaller Free)を使っても、ダメな場合があります。
      調子の良い時のバックアップは、きっと役に立ちます。後々泣かない為に、完全バックアップを作って下さい。
   完全バックアップNG
     ここから先に進む前に、PCを完全にしてください。
     方法は、ここでは示しません。ネット検索して、自分の症状にあった処置をしてください。
   完全バックアップOK
     引用サイト例、Quotation site example : Devo7E を購入~Deviatioin化/スイッチ追加~
              go-gadgetgadget.blogspot.jp/2016/05/devo7e-deviatioin_4.html
     ネット検索すれば、Devo→Deviation化の記事が見つかります。
 6-2.取説や、 ネット検索、このサイトで見つかった情報などから、必要なダウンロードファイル名などをリストします。
   それらを、ひとまとめにせずに、種類別や、機能別にサブフォルダに入れていきます。
   新旧版があり、どちらを使って良いか解らない場合は、両者を取得しておきます。
   →グラフィックスドライバの例を取るまでも無く、新しい≠正常に動く、では無いので、
    場合によって、新、旧版両者の保有が必要になるかもしれません、
Last edit: 15 Nov 2017 12:01 by daive.
20 Nov 2017 01:23 - 29 Nov 2017 10:27 #66008 by daive
※(省略):必要な方は、翻訳サイト等で、翻訳してください。
 翻訳サイト例:https://www.excite.co.jp/world/english/
<<Jumper T8SG 取説>>抄訳
     というか、取り敢えず、Firmware アップデートに必要な部分だけ。
     必要な部分の抄訳が終わってから、試しながら、テキストを変更していきます。
ーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーーー
Contents :目次
  (省略)
CHAPTER 1:Overview:概要
(CHAPTER 1 は、全文省略してあるが、大切な事、重要な事が、書かれているので、出来れば読んで欲しい。
     抄訳をしてないからといって、使用者は法的義務、免責事項を逃れられるわけではありません。)
  (省略)
1.1 Disclaimer:免責事項
  (省略)
1.2 Notices:告知事項、お知らせ
  (省略)
1.3 Legal status and copyright:法的権利、著作権について
  (省略)
CHAPTER 2:Installation:インストール
Windows ユーザーは、deviation firmware の、インストールについて、2種類の方法が選べます。
 1.Deviation Uploader tool
 2.DfuSe USB Upgrade tool(Windows ユーザーのみ)
Windows ユーザーでない場合は、1.Deviation Uploader tool が選択肢になります。
(省略)
2.1 Preparation:準備
まず、最初に、バッテリを完全に充電してください。
ダウンロードするファームウェアの、ファイル名と、ダウンロード元は、以下の通りです。
29/NOV/2017 現在、T8SG 用は、
  Nightly Builds:
           www.deviationtx.com/downloads-new/category/13-nightly-builds
           www.deviationtx.com/downloads-new/category/808-2017-11-16
           www.deviationtx.com/downloads-new/category/812-2017-11-18
           www.deviationtx.com/downloads-new/category/814-2017-11-21
           www.deviationtx.com/downloads-new/category/816-2017-11-23
           www.deviationtx.com/downloads-new/category/819-2017-11-24
  2017-11-16版 :https://www.deviationtx.com/downloads-new/category/810-2017-11-16
  ファイル名:deviation-t8sg-v5.0.0-0210b19.zip
  2017-11-18版 :https://www.deviationtx.com/downloads-new/category/812-2017-11-18
  ファイル名:deviation-t8sg-v5.0.0-06c2f7d.zip
  2017-11-21版 :https://www.deviationtx.com/downloads-new/category/816-2017-11-21
  ファイル名:deviation-t8sg-v5.0.0-0e03636.zip
  2017-11-23版 :https://www.deviationtx.com/downloads-new/category/814-2017-11-23
  ファイル名:deviation-t8sg-v5.0.0-7eca2d7.zip
  2017-11-24版 :https://www.deviationtx.com/downloads-new/category/814-2017-11-24
  ファイル名:deviation-at9-v5.0.0-be57e84.zip
  今現在では、T8SG ファームウェアは、以下の場所には、ありません。
  Deviation 5.0.0:https://www.deviationtx.com/downloads-new/category/398-deviation-5-0-0
  T8SG Deviation バージョン番号例:deviationdevoXX-x.y.z.zip
     x,y,z が、バージョン番号になります。
注意:STMマイクロエレクトロニクス(STMicroelectronics)の DfuSe tool は、決して使用しない事!
(以前から、STM8 / 32 の開発を行っていた方や、ST-LINK V2 を使っていた方は、要注意です。 )
Deviation 用 DfuSe tool のダウンロード元:https://drive.google.com/drive/u/0/folders/0B6SupsT8-3_BYXNQM1dOUlRYcGM
 Dfuse USB Upgrade Tools 1.4.zip
 Dfuse USB Upgrade Tools 1.5.zip
 Dfuse USB Upgrade Tools 1.7.zip
 Dfuse USB Upgrade Tools 2.0.zip
 Dfuse USB Upgrade Tools 2.3.zip
 Dfuse USB Upgrade Tools 2.31.zip :これをダウンロードするのかな?
Deviation 用 Uploader tool のダウンロード元:http://deviationtx.com/downloads-new/category/ 161-dfu-usb-tool
DFU USB Tool :
 DeviationUpload-0.8.0.jar   : これをダウンロードするのかな?
 DeviationUpload-0.7.0.jar
 DFU USBDrv Installer-1.1.zip : Uploader tool 用のドライバかな?
慌てずに! Windows ユーザーは、USB ドライバーのインストールが必要です。
まずは、Windows ドライバーインストール から、行ってください。
「慌て者さん、せっかちさんへ、」
ドライバー入れずに、T8SG と PC を繋いでしまって、
ドライバーが「?」になっている場合や、
ドライバーを入れても「?」が消えない場合には、方法がありますが、
上手く行かない場合は、Unistaller でドライバのアンインストールです。
⇒最悪は、先に行っていてた、HDDの完全バックアップからのリカバリを行います。
 1.USB ケーブルを外す。PCの電源を入れなおす。
 2.Windows用ドライバーをインストールする。↓ を読んでから。
 3.T8SG と PC をUSBケーブルで接続する。Windowsの管理ツールでドライバーの状態を確認する。
   OK:よかったですねぇ。
   NG:「?」のプロパティで、ドライバーの更新で、ドライバーが認識出来るといいですねぇ。
Zip / Unzip ツールが無い場合は、PCへインストールして置いてください。
ダウンロードしたツール類を、ローカルHDDへ解凍します。
Deviation Uploader tool を使う場合は、解凍は必要ありません。
T8SG の最初のアップデートや、TX(送信機、送信モジュール?)のアップデート、
バージョンの異なる、Jumper firmware からのアップデートでは、
DfuSe tool を使った、アップデートが推奨されます。
前のバージョンから、新しいバージョンへアップグレードする前に、
'models' ディレクトリの 設定をバックアップして下さい。
  tx.ini , hardware.ini
 モデル、通信機の設定を無くさないようにしてください。
2.1.1 Windows Driver Installation:Windows ドライバーのインストール
DfuSe toolと、Deviation Uploader tool は、違うドライバを使用しますが、
共存可能で、アンインストール可能です。
Deviation USBDrv Installer のダウンロード元:http://www.deviationtx.com/downloads-new/category/ 161-dfu-usb-tool
Deviation USBDrv Installer を解凍して、‘DFU USBDrv Installer-x.y.exe’を実行します。
Deviation USB Driver は、Deviation Uploader と、Jumper driver 用です。
DfuSe tool は、使用予定がある場合に、インストールしてください。
 この、DFU USBDrv Installer-1.1.exe を起動すると、次の様に2種類の
 ドライバーを、個別にインストールする事ができます
    Select which driver use for your Walkera Transmitter
    ●Install Deviation USB driver (for Deviation-Uploader)
    〇Install Walkera USB driver (for DfuSe USB upgrade)
    〇Remove all DFU drivers (and don't install any new ones)
          Insall ボタン
   Install Deviation USB driver (for Deviation-Uploader) を実行すると、
   usb_driver フォルダが作成されて、、
     Faild to install drivr:Other error
   になっちゃいましたねぇ。
   Install Walkera USB driver (for DfuSe USB upgrade) を実行すると、
   Mcirosoft PnP ユーティリティ画面が表示されて、
   システム上のデバイスへのドライバーインストールに成功しました。
   ドライバーパッケージが正常に追加されました。
   公開名:oem56.inf
   こっちは、正常にインストールできたようです。
2.2 DFU Installation With Walkera DfuSe:DFU と、Walkera DfuSe インストール、
Deviation のインストールや、Deviation の firmware のアップデートに、DfuSe tool を使う場合には、幾つかの注意事項があります。
原文:Note that Deviation will NOT overwrite models stored on the transmitter.
      While they cannot be accessed by Deviation,
      they will be safely preserved should the firmware ever need to be reinstalled
注意:Deviation は、送信機(トランスミッター)に保存されていた、モデル情報を上書きしません。
   それらにアクセス出来ない間は、安全に保たれます。
   firmware は、再インストールの度に、それらを必要とします。
(変な翻訳になっているなぁ)
 Walkera Dfuse USB Upgrade Tools 2.31.exe を起動すると、
  Setup-devention Upgrade Tools
  Wlecome to ... (省略)
          Next ボタン、Cancel ボタン
  が、表示されるので、’devention Upgrade Tools’のまま、インストールしてみます。
  インストールされた、アプリを起動すると、取説の画面の様に起動しました。
おさらい
  T8SG 'ENT' を押したまま、電源ON:USB ファイルモード、液晶画面にUSBの記号が表示される。
  T8SG 'EXT' をおしたまま、電源ON:プログラミングモード:DfuSe モード、液晶画面は、暗いまま。
ここまででやった事
  Windows 用ドライバーを、2種類入れてみた。Deviation-Uploader の方がインストールエラーっぽいが、
  ドライバーフォルダは出来ていた、x86 / x64 用ドライバー登録プログラムがいる。
  T8SG を USBファイルモードで起動して、バックアップした。
  バックアップついでに、メモ帳:Notepad で、hardware.ini , tx.ini をみると、1行表示になっている、
  どうやら、行末:Termination が、C/R,L/F でなく、C/R か、L/F のみの様子。
  そこで、VxEditor など、行末が、C/R, L/F , C/R+L/F 何れでも開ける、フリーエディタを使う事にする。
  VxEditor で開いてみると、正しく開けた。コメント部分を端折って、必用そうな部分のみ、転記しておきます。
 【hardware.ini 抜粋】
  (原文は、英文字部分のみ、行末:Termination の問題があるので、メモ帳編集はダメ:Notepad edit ✖)
   ;Add nostock if stock FMOD and HOLD switches have been removed.
    extra-switches = nostock
    extra-switches = 3x4  、3ポジションSW×4個?
   ; extra-switches = 2x2  、コメントアウト、2ポジションSW×2個?
    extra-switches = potx2 、ポテンションメーター(ボリューム)×2個?
   [modules]
   ; enable-cyrf6936 = B12  、コメントアウト、CYRF6936-40LTXC :http://japan.cypress.com/part/cyrf6936-40ltxc
   ; has_pa-cyrf6936 = 1   、コメントアウト
    enable-a7105 = A13  、MCU Port-A13 ?
    has_pa-a7105 = 1   、モジュール実装個数?それとも?
    enable-cc2500 = A14   、MCU Port-A14 ?
    has_pa-cc2500 = 1
    enable-nrf24l01 = A15   、MCU Port-A15 ?
    has_pa-nrf24l01 = 1
   ; enable-multimod = A13  、コメントアウト
 設定値の解説は、↓ から
 Enabling External Modules to Your Deviation Transmitter:https://www.deviationtx.com/wiki/rf_module_installation/enabling_modules
  【tx.ini】
   tx.ini は、VzEditor で、表示できないコードをスペースに置き換えますというメッセージが出てくるので、
   エディターでの編集は辞めた方が良さそう。
 DfuSe Tool で、2017-11-24 へのUpgrade は、成功しました。
 About Deviation : t8sg-v5.0.-be57e84
 に、なっています。
 T8SG のファイルの上書きは、Tera Copy を使えば、ファイル単位で、ベリファイ可能です。
 walkera の方にDfuse USB upgrade Tools 3 が、有りますが、どうなんでしょうねぇ。
 このツールのベリファイボタンは有効でしたので、ベリファイすると、エラーですねぇ。不安なので未検証です。
 JAVA 版の方は、起動はしましたが、機種不明のままなので、試していません。Java のバージョンやら、調べます。
  。。。。。DfuSe tool ? の画面
予め、ダウンロードして置いた、firmware を解凍します。
次に、T8SGの電源を入れずに、T8SG(送信機:トランスミッター)とPCを、USBケーブルで接続します。
そして、T8SG の EXT ボタンを押したまま、T8SGの電源を入れると、プログラミングモードで起動します。
  1.PCに予め、firmware をダウンロードしておく。
  2.PCの電源を入れて、起動しておく。
  3.T8SG の電源は、切ったまま、PC-T8SG を USB ケーブルで接続する。
  4.T8SG の EXT ボタンを押したまま、T8SG の電源を入れる。
  5.T8SG が、プログラミング モードで起動するはず。
Windows との接続については、接続出来ない場合がある、との報告があります。
DfuSe tool が起動していて、T8SG が認識出来ない場合は、、
(USB ポート番号が他の物に使用されている場合だったりかな?)
USB ポートに接続されている機器を全て外して、
T8SG と、PC のみの接続で、PCを再起動してから、確認してみてください。
一つ一つ確認しながら、問題を解決してください。
DfuSe tool と、T8SG と接続ができると、画面に'STM Device in DFU Mode' と表示され、
画面下側に、'Available DFU Devices' と表示されます。何か問題がある場合は、表示されません。
(上手く接続できなかったり、ドライバーがこけていたり、)
 1.'...' を押して、deviation-vx.y.z.dfu ファイルをインストールします。
   (先の説明にある様に、x.y.z はバージョン番号:読み飛ばした方は、戻って読まれたし。)
 2.'Upgrade' でファームウェアをインストールします。このとき、'Upgrade'がグレーアウト(選択できない)している場合は、
   T8SGを認識出来ていません。
   注意:'Upload' は使用しない事、PC上 のdeviation-vx.y.z.dfuファイルを壊します。
(つまり、T8SG 上の、現在のファームウェアのバックアップという事かな?)
Upgrade が、終了したら、T8SG の電源を一旦切ります。再び、T8SGの'ENT' を押したまま、T8SGの電源を入れます。
すると、USB ロゴが画面へ表示されます。これは、Deviation をインストール後の初回だけです。
PC側では、ドライブ初期化のメッセージが表示される筈です。この時のオプションは、指定せずデフォルトのままです。
次に、ファイルシステムのアップグレードをUSBから行います。
2.3 Upgrading the file system via USB :USB からのファイルシステムアップグレード
On the Devo F7 and F12E, do not enable USB mode, as the file system cannot be accessed from the desktop,
and you need to use the ‘File Manager’ tab on the ‘Deviation Uploader’ to manage files. If you enable it,
all you can do is format the drive, which will destroy your installation.
Devo F7 / F12E は、USB が有効になっていません。ファイルシステムへPCのデスクトップからアクセス出来ません。
'Deviation Uploader' の 'File Manager' タブから、ファイル管理をしてください。
USB を有効にすると、フォーマット可能となり、Devo F7 / F12E のインストールを破壊する事が可能になります。
PCから、解凍しておいた、zipフォルダーを開きます。全てのファイルを T8SG のUSBドライブへコピーしますが、
'zip' と 'dfu' の拡張子が付いたファイルは、コピーする必要がありません。
ファイルシステムの詳細は、USB & File-system を見て下さい。
注意:tx.ini , hardware.ini は、T8SG のファイルと見比べて、両方ともコピーしておくのが、良いかも、
             旧版の'models'フォルダもコピー必用だなぁ)
   現状では、Devo7e onry のフォルダは、T8SG では、要不要不明
   ここで、コピーを始めてしまった方は、死亡フラグが立っているかもしれません。
   説明書は、最後まで目を通してから、実行しましょう。
  。。。。。エクスプローラー の画面
旧バージョンからのアップグレードをする場合には、'tx.ini' と 'hardware.ini' ファイルは書き換えないでください。
'models' フォルダも書換えしません。
'models' フォルダーの内容は、必用があれば、設定済みのモデルのファイルを保存しておいて、コピーします。
注意:この辺は、やってみて、書換予定です。
最後のステップは、('models'のコピーの事?)新規モデルへの、最終版の初期値設定への、対応となります。
もし、'tx.ini' を書き換えてしまった場合は、スティックのキャリブレーションが書き換えられて、初期化されています。
2.4 DFU Installation with Deviation Uploader :Deviation Uploader による DFU インストール
'Deviation Uploader' は、Java(jar) ファイルです。コマンドラインから実行するか、GUIから実行してください。
Java アプリケーションが開きます。但し、Java 実行環境は、予め、インストールしておく必要があります。
www.java.com/
(推奨バージョン、エディション不明)
'Deviation Uploader' が起動したら、T8SG とUSB ポートで接続します。
T8SG の 'EXT' ボタンを押したまま、T8SG の電源を入れます。
正常に接続されると、'Transmiter' の表示が、接続されている 送信機のモデルになります。(T8SGになるはず)
ここで、正しくない送信機のモデルが表示された場合は、アップグレードを中止して、フォーラムのヘルプを探してください。
変更前に、Windows の システムインフォメーションから、全てのデバイスリストを確認してください。
もし、Windows の システムインフォメーションに 不明なデバイスが表示されている場合は、
ドライバーのインストールを確認する事、合わせて、T8SG 以外の USB デバイス(機器)を外して確認してください。
先の、Windows と接続出来ない場合の、確認方法を試してください。
 1.'...' ボタンを押して、zip ファイルを選択します。インストールが行われます。この時に、解凍しておく必要は、ありません。
   Deviation Uploader が行います。
 2.初期インストール後、'Replace' と、'Format' が選択された状態になります。
   Devo F7 / F12E は、初期インストール後、'Format' は選択されていません。
 3.'Install/Upgrade' オプションをクリックします。インストールには、数分かかります。暫く待ってください。
   インストールが終了すると、ダイアログボックスがポップアップします。インストール完了です。
 4.T8SG の電源を一旦切って、再度電源を入れます。Deviation のスプラッシュ画面が表示されます。(ここまで来れば、一様成功)
Devo F7 / F12E は、USB モードが有効では無いので、Windows のデスクトップからは、アクセスできません。
'Deviation Uploader' の'File Manager'タブから 行ってください。
Devo F7 / F12E 以外の送信機では、'ENT' ボタンを押したまま、電源を入れると、USB ロゴが表示されます。
Deviation 初回起動時には、PC 上に、'format a drive '(USB ドライブの初期化画面が出る筈)でるので、
フォーマットのオプションは、初期のままです。
2.5 Upgrading the file system with Deviation Uploader :Deviation Uploader によるファイルシステムアップグレード
Devo F7 / F12E は、USB 経由ではアクセス出来ません。電源を入れて、フォーマットしてしまうと、deviation のインストールを破壊します。
deviation firmware ZIP をインストールするには、Deviation Uploader tool を使うのがお薦めで、一番簡単な方法になります。
別な方法
Zip ファイルを解凍して、firmware dfu ファイルだけをインストールして、同じ場所に、 dfu ライブラリをインストールします。
この方法には、有利な点は何も有りませんが、出来るという事。(出来るという事が、大事だよねと、言いたいのかな?)
2.6 Deviation 5.0
長い間お待ちかねの、4.0.1 から 5.0 へのファームウェアのアップデート。。。
(省略)
2.7 Nightly Deviation Builds
Deviation 5.0 relase版に 追加予定の。。。
(省略)
  Deviation User Manual for Jumper T8SG, Release 5.0
  取説の問題点:https://github.com/DeviationTX/deviation-manual/issues
  2.5. Upgrading the file system with Deviation Uploader
  (省略)
2.8 Test Builds
(省略)
2.9 USB & File-system : USB ファイルシステム
Deviation は、全ての設定、ビットマップ、モデルデータなどを、USB ファイルシステムに入れています。
(電源を入れる前に、PCとT8SG をUSBで繋ぎます)
USBファイルシステムと接続にするには、T8SG の'ENT' ボタンを押したまま、T8SGの電源を入れます。
ファイルは、簡単に コピーできます。(Windows ユーザーのみ)
\tx.ini      :T8SG の設定値、トリム設定、キャリブレーションデータ、最後に使ったモデルの番号
\hardware.ini   :T8SG のハードウェア設定、ハードウェアの部分変更
\errors.txt    :firmware のクラッシュログ、リブートログ、デバッグインフォメーションが入っています。
\datalog.bin   :テレメトリーデータ
\media\config.ini :T8SG 用フォント、色設定
\media\*.bmp   :T8SG 用テーマ
\media\*.fon   :フォントファイル
\models\default.i :初期設定モデル、最初に読み込まれるモデル
\models\model*.i :モデルの設定ファイル
\modelico\*.bmp :モデルアイコン
\templates\*.ini :初期設定のテンプレート
\language\lang* :翻訳言語ファイル、UTF-8 , 英語版⇒翻訳語版
※Deviation は、ファイル名:8char.3char 8.3形式を使用しています。ファイル名は、短い形式です。
ここまでの感じとしては、
1.ネット上の、Devo7E の記事で、ファームウェアアップグレードの方法が見つかる。それらと、大きな違いは無い。
2.hardware.ini / tx.ini は、上書きする前に、T8SG からコピーしておく。
3.models フォルダの内容も、コピーしておく
4.テキストファイルの内容を確認する場合には、メモ帳は使えない。
  VxEditor など、行末がC/R , L/F だけでも、行末と認識するエディターが必要
5.Devo 7E Hardware Connections :https://www.deviationtx.com/wiki/hardware/devo7e
  とは、仕様が同じか、違うかは、未確認です。
※ vlad_vy replied the topic: Need testers for USBcode
   www.deviationtx.com/forum/7-development/...or-usbcode?start=120
※以後、後程追加予定※
Last edit: 29 Nov 2017 10:27 by daive.
20 Nov 2017 03:33 - 22 Nov 2017 01:19 #66009 by daive
CHAPTER 3:Reporting Bugs :バグ報告
完全な物はありえない。
このファームウェアは、注意して作ってはいても、テストが成功するには。。。
(省略)
CHAPTER 4:A Note About this Manual:このマニュアルについて
(省略)
CHAPTER 5:Main Page:
CHAPTER 6:Navigating
CHAPTER 7:Main Menu:
7.1 Model menu
7.2 Transmitter menu
7.3 USB
7.4 About Deviation
CHAPTER 8:Transmitter Menu:
8.1 Transmitter config
8.1.1 Generic settings
8.1.2 Buzzer settings
8.1.3 LCD settings
8.1.4 Timer settings
8.1.5 Telemetry settings
8.2 Channel monitor
8.3 Input Monitor
8.4 Telemetry monitor
8.5 Range Test
Chapter 9. :Model menu:
9.1 Model setup (Std & Adv GUI)
9.1.1 Predefined Model Templates
9.2 Mixer (Adv GUI)
9.2.1 Channel Reorder
9.2.2 Channel configuration
9.2.3 Virtual channel configuration
9.2.4 Simple Mix Type
9.2.5 Expo & Dual-Rate Mix Type
9.2.6 Complex Mix Type
9.2.7 Cyclic
9.2.8 Reordering Mixers
9.2.9 Available Curves
9.2.10 Curve Editing
9.3 Timers (Std & Adv GUI)
9.4 Telemetry config (Std & Adv GUI)
9.5 Trims and Virtual Inputs (Std & Adv GUI)
9.6 Datalog (Std & Adv GUI)
9.7 Main page config (Std & Adv GUI)
9.7.1 Configuring object position
9.7.2 Creating Objects
9.7.3 Loading Objects
9.7.4 Configuring Objects
9.7.5 Choosing toggle icons
9.8 Standard GUI Menu items
9.8.1 Servo Reverse
9.8.2 Dual-Rate/Expo setting
9.8.3 Sub-trim Adjustment
9.8.4 Servo Travel Adjust
9.8.5 Swash Configuration
9.8.6 Throttle Curve
9.8.7 Pitch Curve
9.8.8 Gyro Sensitivity
9.8.9 Switch Assignment
9.8.10 Throttle Hold
9.8.11 Fail-Safe Configuration
※後程追加、変更、修正予定※
Last edit: 22 Nov 2017 01:19 by daive.
22 Nov 2017 00:44 - 22 Nov 2017 01:44 #66036 by daive
CHAPTER 10:Protocols:
(最終的には、用語の統一感が必要になる筈
  Aileron, Elevator, Throttle, Rudder など名詞は、
  エルロン、エレベータ、スロットル、ラダー等の、カタカナに治さない方が良いと思う。
  検証出来ない項目については、原文のまま、検証できる部分については、脚注も入れたい。)
10.1 Protocol: DEVO
10.2 Protocol: WK2801
10.3 Protocol: WK2601
10.4 Protocol: WK2401
10.5 Protocol: DSM2
10.6 Protocol: DSMX
10.7 Protocol: J6Pro
10.8 Protocol: *Flysky
10.9 Protocol: *AFHDS-2A
10.10 Protocol: *Hubsan4
10.11 Protocol: *Joysway
10.12 Protocol: *Frsky-V8
10.13 Protocol: *Frsky
10.14 Protocol: *FrskyX
10.15 Frsky and FrskyX Extended Telemetry
10.16 Protocol: *Skyartec
10.17 Protocol: *Futaba S-FHSS
10.18 Protocol: *V202
10.19 Protocol: *SLT
10.20 Protocol: *HiSky
10.21 Protocol: *YD717
10.22 Protocol: *SymaX
10.23 Protocol: *Hontai
10.24 Protocol: *Bayang
 プロトコル使用機体:BayangToys X6,X7,X8,X9
           JJRC/Eachine H8,H10
           JJRC JJ850
  注意:使用に当たっては、'NRF24L01+' モジュールが必要
     "plus" 版では、 nRF デバイスで、250kbits の転送速度をサポートしている必要があります。
     フォロードキュメント:http://www.deviationtx.com/wiki/#hardware_modifications
 最初の4CH分は、Aileron, Elevator, Throttle, Rudder に割り当てられている。
 追加のCHは、スペシャルファンクションとして使用される。
  CH5:未使用
  CH6:flip function 有効
  CH7:写真撮影
  CH8:ビデオのスタート/ストップ
  CH9:ヘッドレスモードのON/OFF
  CH10:オートリターン、自動帰還
10.25 Protocol: *FY326
10.26 Protocol: *CFlie
10.27 Protocol: *H377
10.28 Protocol: *HM830
10.29 Protocol: *KN
10.30 Protocol: *ESky150
10.31 Protocol: *Esky
10.32 Protocol: *BlueFly
10.33 Protocol: *CX10
10.34 Protocol: *CG023
10.35 Protocol: *H8_3D
 プロトコル使用機体:Eachine H8 3D,
           JJRC H20 and H11D
           これ以外はテストしていない。
     注意:‘NRF24L01’モジュールが必要です。
 H8_3D プロトコルは、11チャンネルサーポート、自動バインディングのみのサポートです。
   CH5:LED コントロール
   CH6:Flip モードのコントロール
   CH7:スチルカメラのコントロール
   CH8:ビデオカメラのコントロール
   CH9:ヘッドレスモードのコントロール
   CH10:RTH のコントロール(RT:Retrun to home ?自動帰還)
   CH11:HD11D用のカメラジンバルコントロール、3ポジション
   キャリブレーション:左スティック、下端、左、右スティック、下端、左、H8_3D
   ヘッドレスキャリブレーション:左スティック、下端、右、右スティック、下端、右、H20
10.36 Protocol: *MJXq
10.37 Protocol: *PPM
10.38 Protocol: USBHID
CHAPTER 11:Advanced Topics:
11.1 Setting up a Buddy-Box
11.1.1 Master Mode
11.1.2 Slave Mode
11.2 Setting Up FPV or Other External Inputs
11.3 Using a Trim as a Virtual Switch
11.4 Swash Mixing
11.5 Modifying sounds
CHAPTER 12 : Emulator:
※後程追加、変更、修正予定※
Last edit: 22 Nov 2017 01:44 by daive.
22 Nov 2017 01:18 - 22 Nov 2017 01:46 #66037 by daive
読み直すと、誤字脱字、項目の変な物が沢山あるので、随時修正していきます。
投稿は、Reply が付くまでは、Delete 可能な様子です。
【お願い】
誤字、抄訳(意訳)の不都合箇所は、ご指摘くだされば、有難いです。
必ずしも、原文:PDF版の通りに、機械的な抄訳を行っては、いません。
この手の取説は、使い物になる事が、重要だと思っていますので、
原文に無いコメント、意訳(思い込み)が入っています。
ファームウェアのアップグレードを、取説をなぞってやってみたいのですが、
時間が取れるのが、夜間、週末なので、暫くお待ちください。
Last edit: 22 Nov 2017 01:46 by daive.
22 Nov 2017 18:21 #66063 by FDR
Replied by FDR on topic JUMPER T8SG My problem.
Sorry, but I don't really understand what do you want, and machine translations really don't help.
Can somebody please translate, what it this topic all about?
23 Nov 2017 00:59 #66081 by daive
Thank you very much for your Reply.
↓ Mainly, machine translation ↓
An effort of the explanation will be done.
1.I wanted to know whether it's impossible whether it's possible to connect.
2.Because there are no Japanese instruction manuals.It was part translated.
 抄訳:Part translation
 翻訳:translation
 完訳:Complete translation
3.Can't bind my toy quad , how to ,,,
 Check T8SG protol support .
non support ⇒ transmitter / reciver chip and x-tal OSC , protocol support to do,check forum issue , do it your self ...
Much information is deviationtx.com.
I know that it's an English site.
Because there is no Japanese information.
It's being written for itself.
↑ Mainly, machine translation ↑
13 Dec 2017 17:56 - 13 Dec 2017 18:03 #66489 by daive
JJ/RC H36 Now version , Original JJRC H36 Receiver Board , Now version ,Q X7 & iRangeX IRX4 Plus ready,can be used. (^_-)-☆
下手くそな動画ですが、意図は伝わるかと。
Deviation can't bind ⇒ TARANIS Q X7 & iRX4 plus can be bind.
Deviation 負けるな、がんばれ、Fight!!
amazon.co.jp で 2017-SEP-04 に購入した、
JJR/C H36 がバインドできました。
T8SG では、バインド不可でしたが、
TARANIS Q X7 & iRangeX IRX4 Plus では、
バインド可能となっています。
【設定】
シリアルモード:プロトコルSW=0
Mode:MULT MJXQ , E010
Purchase origin
JJR/C H36 ミニドローン 日本語取扱説明書付き ラジコンヘリコプター 2.4G 6軸ジャイロ 小型(ブルー)
www.amazon.co.jp/gp/product/B073RZVXH7/r...ilpage?ie=UTF8&psc=1
IRX4 Plus : Banggood , arrival 09-DEC-2017
TARANIS Q X7 : Gearbest , arrival 10-DEC-2017
Original JJRC H36 Receiver Board Quadcopter Accessory - GREEN
www.gearbest.com/rc-quadcopter-parts/pp_468512.html?wid=21
Last edit: 13 Dec 2017 18:03 by daive.
01 Mar 2018 09:54 #67837 by daive
JUMPER T8MP 日本向け、技適モデル発売の様子です。
www.hobbynet-jp.com/japan/main2.asp?cate...ポ&category2ID=item63
www.hobbynet-jp.com/japan/index.html
←左側 、下の方へ 、Props 、プロポ 、◆ Jumper_T8MPプロポ
HOBBYNET さんから、返信:2018-FEB-28
Jumper社 T8MP 2.4G 10CH 小型送信機(FRSKY仕様) 技適取得済みなので安心して日本国内でご利用出来ます。
機能 T8MP仕様
周波数 2.4GHz FRKSY仕様
チャンネル 10ch
MCU STM32F103RCT6
メモリー 25VF016B ( 2MB )
RFチップ JP - 4MP ( CC2500, NRF24L01, A7105, CYRF6936 )
出力 10mW(固定)
LCDサイズ 128 x 64, 1.7 inches
バッテリー 4 x 1.5V AA or 2S LiPo ( not included )
本体サイズ 188 x 151 x 86mm
重量 347g
jumper t8mp T8SGの技適通過モデル
T8MP-M1 Jumper T8MP 2.4G 10CH 小型送信機(FRSKY仕様) 技適取得済み(モード1)  15,800
T8MP-M2 Jumper T8MP 2.4G 10CH 小型送信機(FRSKY仕様) 技適取得済み(モード2)  15,800
T8MP購入価格、参考例
本体価格: 15,800
送料  :  800 (沖縄、離島を除く)
消費税  :1,328 (1円未満切り捨て)
合計  : 17,920 (カード決済)
代引きの場合:18,360
ソース:https://blogs.yahoo.co.jp/sab_goblin/42797398.html
16 Mar 2018 02:58 #68117 by Blufires
Replied by Blufires on topic Heliway 901s
I have a Heliway 901s. I can bind it to my T8SG using the "FQ777" protocol. The frame of my quadcopter is damaged, so I cannot confirm flight controls or mixers. I will 3D print a new frame on Tuesday and update the information.
19 Mar 2018 07:08 #68199 by daive
Replied by daive on topic Heliway 901s
Thank you very much for your information.
I'll try.
19 Mar 2018 10:46 #68204 by daive
1.Bind test.
1-1.Controller : H901S
H901S : Bind OK
H901HS : Bind OK
FQ777-124 : Bind NG
1-2.Controller : H901HS,Throttle Spring Center
H901S : Bind OK
H901HS : Bind OK
FQ777-124 : Bind NG
1-3.Controller :FQ777-124
H901S : Bind OK
H901HS : Bind OK
FQ777-124 : Bind OK
1-4.Controller :T8SG / FQ777 / 124 SSV / 3mW
H901S : Bind OK , Propeller revolved.
H901HS : Bind OK , Propeller revolved. need propeller start method
FQ777-124 : Bind OK , Propeller revolved.
Thank you very much , You're great.
22 Mar 2018 05:36 #68264 by daive
T8MP 続報:22-MAR-2018
購入された方がいて、
販売サイトでの
Jumper社製 T8MP 2.4G 10CH 小型送信機(FRSKY仕様)
との 記述の理由が判明しました。
出力/output:10mW 固定/only
プロトコル/Protocol:Frsky / Frsky-V8 / FrskyX / PPM / USBHID
ファームの書換可否/Firmware update:不明 / unknown
これでは、日本は、ドローン後進国のままだ。_| ̄|○
26 Mar 2018 13:27 #68363 by Blufires
901s flies perfectly fine with T8SG. Had to reverse a channel in mixer on Mode 1.
22 Nov 2018 01:17 #71839 by daive
Replied by daive on topic DIY Multiprotocol Tx Module
iRX4+ / Jumper 4 in 1 , lastest firmware
Protocols details
github.com/pascallanger/DIY-Multiprotoco...Protocols_Details.md
41,BUGS
42,BUGSMINI
43,Traxxas
44,NCC1701
45,E01X,E012,E015 <<<<<
46,V911S <<<<<
47,GD00X
Time to create page: 0.068 seconds
