08 Nov 2016 22:14 - 08 Nov 2016 22:17 #55810 by wasp09
Replied by wasp09 on topic 3in1 / 4in1 RF module
That wasn't designed for working with 1S then.
I am using 2S on my 7E and 3S on my 10. I don't have a 12 to worry about at this moment.
The easiest way is to add an power converter to step it up in front or simply bypassing if the LDO on the 12 is good enough. Or else as I said, we may have to get the VCC down to 3V, i.e. replacing the 1117 onboard. 3.3V from 1S is simply too tight.
The 1117 datasheet I have shows dropout is still around 1V at Iout of 100mA. Some crazy protocol like KN will be taking more than that. If you stick to 1117-3.0, you probably have to double/triple it up to reduced the shared Iout below 100mA.
Last edit: 08 Nov 2016 22:17 by wasp09.
09 Nov 2016 02:00 #55811 by 1down5up
Replied by 1down5up on topic 3in1 / 4in1 RF module
Is this the correct "4 in 1 module" I want for the 7e?
[url=CC2500 NRF24L01 A7105 CYRF6936 4 In 1 RF Module For Walkera Devo Transmitter https://banggood.app.link/TLRxadCP7x]BangGood: 4in1 Module[/url]
09 Nov 2016 05:07 #55814 by vlad_vy
Replied by vlad_vy on topic 3in1 / 4in1 RF module
Yes, it's only one correct "4in1 module" for all Devo transmitters.
09 Nov 2016 06:04 #55815 by 1down5up
Thanks for the replies!
12 Nov 2016 13:22 - 12 Nov 2016 13:23 #55869 by jayodas
Replied by jayodas on topic 3in1 / 4in1 RF module
Hi everyone, just reporting back in here regarding my 3in1 module that I installed in my Devo 7e.
I've been experiencing problems controlling my Eachine e010 when transmit power is set above 1mw.
I just added a 3.3v voltage regulator following this post by robpur and it is working but the problems with controlling the Eachine e010 have not gone away.
So, I guess Goebish is correct in suspecting that the 3in1 module doesn't contain a genuine NRF24l01 chip set. It's definitely very disappointing.
Last edit: 12 Nov 2016 13:23 by jayodas.
12 Nov 2016 19:42 - 12 Nov 2016 19:43 #55876 by Cyberhornet
Replied by Cyberhornet on topic 3in1 / 4in1 RF module
Hi !
I would like to buy this 4 in 1 module www.banggood.com/CC2500-NRF24L01-A7105-C...tml?rmmds=mywishlist
But i have a F12E with deviation firmware
The problem is that I do not know where solder the pins " 2401, 2500, 7105"
pics from F12E inside: www.walkeraonline.com/inside%20WALKERA%20Devo%20F12E
Thank you !
Last edit: 12 Nov 2016 19:43 by Cyberhornet.
13 Nov 2016 03:28 - 13 Nov 2016 03:30 #55882 by Arnold
Replied by Arnold on topic 3in1 / 4in1 RF module
Cyberhornet wrote: The problem is that I do not know where so lder the pins " 2401, 2500, 7105"
7105 = TMS pad (A13)
2500 = TCK pad (A14)
2401 = ????
Last edit: 13 Nov 2016 03:30 by Arnold.
13 Nov 2016 06:17 #55887 by vlad_vy
It looks like there is not any unused pads for Devo F12E, so look at Devo 8s connections:
www.deviationtx.com/forum/7-development/...dule?start=940#55157
13 Nov 2016 07:13 #55889 by victzh
Replied by victzh on topic 3in1 / 4in1 RF module
Cyberhornet, I can't help you with finding an extra pad on F12E, but could you do me a favor?
On one of the pictures where the CYRF6936 module is placed, there is a set of labels for the signals.
They correspond to the pins on the module. The labels are: 5V, IRQ, RESET, NC, SS, SCK, MISO, MOSI, GND.
This is new for Devos - they usually lack IRQ contact. Can you trace the IRQ line to its corresponding pin on the module and tell me what is it? I'm making the plug-in solution which would not require the soldering for Devos with this kind of module, but I needed to connect one of the unconnected pins of the older versions. Maybe I picked a wrong pin and my solution will fail for F12E. I'd like to avoid it, naturally.
Thanks in advance,
Victor.
13 Nov 2016 12:34 #55894 by Cyberhornet
2401 = ????
Thx Arnold ! If someone knows where to find a free pad on this radio it would be great !!!
For Vlad_vy, thx but my F12E don't have the same pcb :(
For victzh:
I hope that's what you want ?
13 Nov 2016 13:46 - 13 Nov 2016 13:50 #55895 by ajtank
Replied by ajtank on topic 3in1 / 4in1 RF module
If the information listed here is correct then GPIO B6 and B7 are unused. However you might need to solder directly on the processor if the GPIO's have not been extended to solder pads on the board.
Sorry you are talking about F12E not 12E. I am unsure if the above applies or not.
Last edit: 13 Nov 2016 13:50 by ajtank.
13 Nov 2016 14:03 #55896 by Cyberhornet
it's here for F12E : www.deviationtx.com/wiki/hardware/devof12e?s []=f12e
I'm not an expert in electronics
It would be nice that everything works but I need flysky and frsky protocol
13 Nov 2016 15:30 #55897 by ajtank
Then you can try GPIO C14 for nRF24L01.
13 Nov 2016 16:19 #55900 by vlad_vy
GPIO B3 is also unused and you can solder third wire (2401) the same way as for Devo8, to MCU pin 89.
13 Nov 2016 18:05 - 13 Nov 2016 19:01 #55904 by Cyberhornet
Thank you so much !
A final beginner question:
I do not know where pin 89 is on the MCU And what should be written in the .ini file ? ^^ Same as Devo 8 ?
Last edit: 13 Nov 2016 19:01 by Cyberhornet.
13 Nov 2016 20:24 #55909 by victzh
@Cyberhornet, thanks a lot. It's very disappointing - I took wrong pin! But it's good I caught it early thanks to you!
14 Nov 2016 01:06 #55911 by ajtank
On the wiki page there is a link to the MCU datasheet. I capture the pinout below for your convenience:
If you connect NRF24L01 to PB3 (pin89) then put B3 in the ini file:
enable-nrf24l01 = B3
has_pa-nrf24l01 = 1
Good luck.
14 Nov 2016 01:11 #55912 by Cyberhornet
Thank you ajtank ! I am waiting for my module and will give you news :)
You are welcome victzh ;)
14 Nov 2016 04:06 #55914 by ajtank
I am no better than you. I spent a month reading posts on this forum and added the 4-in-1 on my Devo 10 in Oct. So I am just another newbie.
14 Nov 2016 04:14 #55915 by vlad_vy
Cyberhornet wrote: Thank you so much !
Look at Devo8 connections, it has the same MCU.
Time to create page: 0.233 seconds
