Ultimate Devo F12E (devof12e-XMS) builds
24 Feb 2017 16:21 - 25 Feb 2017 15:36 #59567 by vlad_vy
Replied by vlad_vy on topic Ultimate Devo F12E (devof12e-4MB) builds
*Fixed reboot at Telemetry Monitor page for Frsky(X) protocol.
DevoF12E and DevoF12E-4MB, with fixes, based on Nightly Builds:
Files deleted, see below...
Last edit: 25 Feb 2017 15:36 by vlad_vy.
24 Feb 2017 17:16 #59570 by M8A4X
Replied by M8A4X on topic Ultimate Devo F12E (devof12e-4MB) builds
Like commented in the FrskyX protocol thread, no reboot any longer! ;)
The F12E is more and more becomming my favourite Transmitter!
25 Feb 2017 05:24 #59597 by M8A4X
Maybe this is just an issue on my tx, but when entering "Model menu --> Model setup --> Icon" first the screen is blanc for about a second and then the tx reboots. The standard heli.pbm file is present in the "modelico" folder on the tx. No other files are in this folder.
This issue maybe is only a problem to me because:
I can´t use the Dfuse tool to upload to the transmitter, the tx is not detected in the DfuSe tool.
The USB drivers are installed "for DfuSe USB Upgrade".
In the device manager (Win10x64), when the F12E is connected in "Program Udpate.." mode, a USB-device "STM32 DFU" is shown. However in the DfuSe tool there is no device shown in the "Available DFU Devices" dropdown menu (don´t know if this matters but DfuSe is only "Demo (v3.0.5)".
I therefore used the DeviationUpload-0.8.0 java-tool (with according drivers installed) for installing and copying the files to the transmitter.
Maybe I screwed up something when uploading Deviation to the tx this way?
25 Feb 2017 05:43 - 25 Feb 2017 05:56 #59598 by vlad_vy
I don't think that problem related to DeviationUpload-0.8.0 java-tool. I my case I havn't reboot with "Model menu --> Model setup --> Icon", but the icon image is not displayed. If I select "heli.pbm" then icon image disappeared from main screen. So for the moment we can't use any icon except "Default".
Until now I can't fix problem with load icon image.
Do not use "ST Demo" software, you can erase Tx bootloader. I use Dfuse USB Upgrade Tools v2.31 with my old Windows XP:
walkera-fans.de/download/tools/dfuse/Dfu...e%20Tools%202.31.zip
Last edit: 25 Feb 2017 05:56 by vlad_vy.
25 Feb 2017 09:18 #59600 by M8A4X
Ah, ok! Just take your time, vlad.
I tried the DefuSe version you have linked. Also no success in getting the F12E showing up.
What keeps me wondering is when I upload the deviation.zip in DeviationUpload-0.8.0 and select the "format" option, after a reboot all my models and settings are still present. Shouldn't everything has been wiped from the tx?
Or should I only update the DFU file, do the formatting by windows and put on the remaining files and folders by hand?
25 Feb 2017 10:55 - 25 Feb 2017 12:22 #59607 by vlad_vy
For DfuSe, try manually install driver from program folder \Program Files\devention Upgrade Tools\Driver\
Look at these threads, probably it can help:
www.deviationtx.com/forum/how-to/2787-in...e-on-windows-7-8-8-1
www.deviationtx.com/forum/3-feedback-que...dfuse-windows-10-x64
I don't use DeviationUpload-0.8.0 so I can't help with it.
If code change do not any changes to USB filesystem, you can update the DFU file only. At other case you can simply rewrite changed files at USB drive. You need format USB drive by windows for first install only.
Last edit: 25 Feb 2017 12:22 by vlad_vy.
25 Feb 2017 15:35 - 26 Feb 2017 10:25 #59613 by vlad_vy
*Fixed change icon for Devo F12E
Now we need nice BW *.pbm images for model icons (72 x 46, up to 72x72 pixels)!!!
Last edit: 26 Feb 2017 10:25 by vlad_vy.
25 Feb 2017 15:48 #59615 by vlad_vy
M8A4X,
can you test will it work for you?
25 Feb 2017 18:04 #59623 by M8A4X
;) Tested: It works!
No reboot any longer!
The nice Quadcopter image you have in your screenshot, as it seems not to be included in the*.zip, can you upload it as an attachment?
If I can help you with creating these images in any way, let me know. (The filetype *.pbm is pretty uncommon, at least to me...)
25 Feb 2017 19:37 #59627 by FDR
@Vlad
As far as I understand the F12E has a color graphic display.
Do you plan to make the ultimate F12E to have a full graphical display at least like the BW transmitters?
It could have custom fonts then, which would make possible to use different languages as well.
Of course the main page could be different not to mess up the FPV display...
26 Feb 2017 03:08 - 26 Feb 2017 03:52 #59637 by vlad_vy
No, it is video display with OSD text windows. For example, XY-graph and icon drawing at one 6x4 chars (72x72 pixels) window, I think as a RAM font. Toggles drawing as a RAM font.
Last edit: 26 Feb 2017 03:52 by vlad_vy.
26 Feb 2017 04:44 - 26 Feb 2017 04:44 #59641 by vlad_vy
I can save images as *.pbm with IrfanView, can edit and save as *.pbm with GIMP. At both cases *.pbm images have header with comments that Deviation can't reed. So, they need editing with binary or text editor to cut out comments from *.pbm image.
P4
# Created by IrfanView
72 46
xxxxxxxxxxxxxxxxxxxxxxxx
to
P4
72 46
Last edit: 26 Feb 2017 04:44 by vlad_vy.
26 Feb 2017 04:56 #59642 by vlad_vy
Forget to say:
* Added "Debuglog" page for "text" GUI (for developers)
It greatly help me to fix "change icons for Devo F12E".
26 Feb 2017 05:54 - 26 Feb 2017 06:12 #59644 by M8A4X
Thanks for the eachine icon, vlad! Hey, at least it looks definitly like a quadcopter ;)
I just tried creating a model icon based on your eachine icon, drawing in gimp is a pain (at least for a new user like me)...
You can draw in Windows-paint, but it lacks a lot of drawing tools.
The various picture altering tools in irfanview are nice, but without a good basis image it is difficult to get an acceptable result.
The attempt of bringing an image of e.g. a racequad down to size of 72x72 pixel maximum is not quite easy.
The information about the header which has to be removed is crucial as the Devo would not show the images when the header is still present.
Just for fun you can find attached the model icons i tried to generate, try not to laugh :)
Edit: The model icons of the Taranis can be used after Inverting black&white and resizing to a maximum pixel length or height of 72.
But I don´t know if they are copyright protected (even if opentx is open^^), but the steps are simple with irfanview.
Last edit: 26 Feb 2017 06:12 by M8A4X.
26 Feb 2017 09:55 #59646 by FDR
vlad_vy wrote: No, it is video display with OSD text windows. For example, XY-graph and icon drawing at one 6x4 chars (72x72 pixels) window, I think as a RAM font. Toggles drawing as a RAM font.
Ah, I see, thanks!
26 Feb 2017 10:24 - 27 Feb 2017 07:22 #59647 by vlad_vy
* Fixed read PBM file header including comments. Now we can use BW *.pbm images from any editor, no need to edit file header.
Known bugs:
* Model "Icon" load/change page doesn't display icon image.
* D/R can't be greater 100%, with 102% transmitter freeze and reboot. Probably it can be related to XY-graph.
* At "Throttle curves" and "Pitch curves" pages, value fields for inactive YX-graph points have not any visible highlight or cursor.
* Deviation can't use *.pbm files with header including comments. So I need erase header comment with binary (or text) editor.
Last edit: 27 Feb 2017 07:22 by vlad_vy.
27 Feb 2017 07:21 - 28 Feb 2017 18:38 #59674 by vlad_vy
* Fixed selection on curves pages for text GUI (Mixer GUI "Standard")
Before fix (inactive (or locked) M point, no visible selection at all):
After fix (inactive (or locked) M point):
Known bugs:
Last edit: 28 Feb 2017 18:38 by vlad_vy.
28 Feb 2017 18:04 #59720 by M8A4X
Hi Vald!
Your progress is really great!
May I ask what happened to your attachments of deviation with language support?
28 Feb 2017 18:37 - 01 Mar 2017 13:56 #59721 by vlad_vy
With last Nightly Build changes I have the problem with "Mixer" page after visit "Toggle select" page, so I decided to return to 24.02.2017 Nightly Build version with added latest fixes.
Also, about language support, I get some problems with Latin supplement symbols, they collide with "toggle" icons (actually RAM font chars). So I need more work with code. Now it looks like I can provide full language support for languages based on Latin charset. Of course, for DevoF12E-4MB only. Devo F12E has not filespace for language files.
Romanian language file is incorrect, so I deleted it from build. File "lang.ro" has not UTF-8 encoding.
Last edit: 01 Mar 2017 13:56 by vlad_vy.
28 Feb 2017 19:36 #59724 by FDR
Have you identified which change broke that?
I have an 00ea1f0 build, and it works fine.
Since that most of the changes were mine, except your debuglog and curves pages...
Time to create page: 0.156 seconds
