KingKong Tiny7 DSM2 Devo F12E
- RubenRC
- Topic Author
05 Jun 2017 19:03 - 04 Aug 2017 17:40 #62840
by RubenRC
DEVO F12E | Devo F7
KingKong Tiny7 DSM2 Devo F12E was created by RubenRC
Hey everyone,
Here is my ini for my KingKon Tiny7. It currently uses Aux 1 to arm. Aux 2 is for modes: Air,Angle and Horizon.
Enjoy!
Enjoy!
DEVO F12E | Devo F7
Last edit: 04 Aug 2017 17:40 by RubenRC.
- X_Marine
13 Jul 2017 00:58 #63417
by X_Marine
Replied by X_Marine on topic KingKong Tiny7 DSM2
Hey thanks for the file.
I have had my Devo7e for some time and installed Deviation already and now finally got the Tiny7 with DSM2 and am now searching for a little help on binding etc..
I'm sure this will prove helpful once I figure how to get it installed proper.
Any further help on using your ini file would be appreciated.
Many thanks.
X_Marine/BillyD..
Many thanks.
X_Marine/BillyD..
- RubenRC
- Topic Author
13 Jul 2017 01:32 - 13 Jul 2017 01:32 #63418
by RubenRC
DEVO F12E | Devo F7
Replied by RubenRC on topic KingKong Tiny7 DSM2
You'll have to unscrew the canopy. The transmitter will have a gold button. Press it while connecting the battery puts it in bind mode. Then just bind your controller and you should be in business.
DEVO F12E | Devo F7
Last edit: 13 Jul 2017 01:32 by RubenRC.
- X_Marine
14 Jul 2017 23:57 #63451
by X_Marine
Thanks for the reply.
In your ini it states your using 7 channels.
I'm thinking I need to set mine up for 7 channels.
Or if I copy your file over mine maybe that will do it.
Your ref to aux1 and aux2 I guess means HOLD and FMOD switches?.
Again thanks for your help, I have a lot to learn.
X/BillyD..
X/BillyD..
- X_Marine
15 Jul 2017 01:30 #63452
by X_Marine
Ok, took me a while to find how to boot into the usb mode, I need to make better notes. ')
For anyone looking, "Hold ENT while powering up radio".
I copied your model1.ini over mine and like magic I have a Tiny7 to select.
I then Calibrated my sticks.
Then went to BIND and seems like my Tiny7 sees the radio and flashing amber quits so I powered off the quad and the radio.
When I restart it seems like it sees the radio but flipping my Hold switch does not lock it in and I have no throttle.
I must be doing something wrong after binding?.
Feels like I am really close.
Many thanks.
X/BillyD..
Many thanks.
X/BillyD..
- RubenRC
- Topic Author
15 Jul 2017 02:02 #63453
by RubenRC
DEVO F12E | Devo F7
Hey X_Marine
I'm using this ini with my Devo F12E. So the switches might be different. Hook your Tiny7 to Betaflight. Then go to the receiver move the switches and see if any respond you can also check your flight sticks.
DEVO F12E | Devo F7
- X_Marine
15 Jul 2017 02:12 #63454
by X_Marine
Thanks Ruben, that would explain whats up.
Can't remember if I have Betaflight on this notebook or not but if not I'll try and load it.
I might check some other ini files that are for the 7e and see if I can adjust from there.
I'll report if I have any luck.
Many thanks.
X/BillyD..
Many thanks.
X/BillyD..
- RubenRC
- Topic Author
15 Jul 2017 03:01 #63455
by RubenRC
DEVO F12E | Devo F7
Yeah sorry. I'll have to update my post so everyone knows it's setup for a F12E. But changing the switches is easy. Just use the receiver screen to figure out which switch you want to us to arm and change modes. And got to switches tab then plug in the right aux channel to arm and change modes. You should be good then. Betaflight is easy to install the chrome plug-in.
Good luck!
Good luck!
DEVO F12E | Devo F7
- X_Marine
15 Jul 2017 15:42 #63462
by X_Marine
Just noticed you put scrn caps up, that will help if I can get Betaflight going.
If I can't find something maybe on the Tiny6 I could possibly use then I'll grab BF and see if I can fix yours up.
One thing I was wondering is, do we have any info on what these are capable of?. Like does it have anything like flip etc. or is all that totally up to the user and their ability to set it up?.
Guessing I need to yell at Sebocky?? and maybe he has a DSM2 ini file around. ')
Again really appreciate all your help.
X/BillyD..
X/BillyD..
Time to create page: 0.040 seconds
- Home
- KingKong Tiny7 DSM2 Devo F12E
