Waring: v2.0 is not reliable
09 Dec 2012 17:49 - 09 Dec 2012 17:49 #3828 by HiNote
Replied by HiNote on topic Waring: v2.0 is not reliable
Joshua wrote: I testet the new Version today with all my different modells.
No reboot, no other problems! ;)
Thanks for this update.
+1
I tested latest version in Phoenix and my MiniCP and OK. No reboots now.
Last edit: 09 Dec 2012 17:49 by HiNote.
11 Dec 2012 15:50 #3879 by flint723
Replied by flint723 on topic Download page updated?
PB, I was just curious if you have the fixed version on the main v2.0 download page? or is it only here in this forum?
11 Dec 2012 16:18 #3880 by vlad_vy
Replied by vlad_vy on topic Waring: v2.0 is not reliable
Safety warning (throttle position at power on) doesn't work. But other safety warnings (not related to throttle position) work fine. With any of these warnings I can see also throttle position and throttle safety warning .
[safety]
Auto=min
RUD DR=min
FMODE1=min
FMODE2=min
11 Dec 2012 17:32 #3883 by PhracturedBlue
Replied by PhracturedBlue on topic Waring: v2.0 is not reliable
It should be fixed now, but I don't have a tx in front of me, so please someone verify.
11 Dec 2012 17:35 #3884 by PhracturedBlue
Replied by PhracturedBlue on topic Download page updated?
There has been no official release since 2.0. The one in this thread seems to have fixed the reboot issues, but still has known bugs. I hope to do a fixed release sometime this week that will become 2.1
11 Dec 2012 17:41 #3885 by sbstnp
Replied by sbstnp on topic Waring: v2.0 is not reliable
PhracturedBlue wrote: It should be fixed now, but I don't have a tx in front of me, so please someone verify.
Looks ok, tested with a few models both Devo and FlySky.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
11 Dec 2012 19:44 #3890 by quique65
Replied by quique65 on topic Download page updated?
Perfect!!, waiting patiently..
Good job, thank you very much.
12 Dec 2012 02:22 #3903 by flint723
Replied by flint723 on topic Waring: v2.0 is not reliable
I can verify that with the latest version posted in this thread, the throttle safety on power on does not work. It does work when switching models.
12 Dec 2012 05:53 - 15 Dec 2012 17:06 #3904 by Hexperience
Replied by Hexperience on topic Waring: v2.0 is not reliable
That's correct. PB doesn't build a new release after each bug fix. If you really want to be on the cutting edge, you'd need to install the build environment and compile it yourself.
Having said that, here's the latest version for devo8 (d66713fda604). Again, you'll see the version with "hex" then the last four digits of the version code. All that indicates is that I compiled it, and that it is NOT an official release version.
PB, I hope it's ok with you that I post these, if not let me know.
Cheers
Last edit: 15 Dec 2012 17:06 by FDR. Reason: removed obsolete attachments
15 Dec 2012 12:11 #4011 by RugWarrior
Replied by RugWarrior on topic Waring: v2.0 is not reliable
Hi.
I use Devo 8S with QR Ladybird (Devo) and when I unplug the battery from the model my screen is displaying the last volatge on main screen box but with red background. Is this wanted or should it better turn to e.g. "-" (do not display a value) :huh: ?
PS: Great project! And with the mentioned build I have no problems so far :)
15 Dec 2012 15:06 #4014 by FDR
Replied by FDR on topic Waring: v2.0 is not reliable
To keep our backup size reasonable, can I delete the older ones?
15 Dec 2012 16:25 - 15 Dec 2012 19:13 #4015 by PhracturedBlue
I removed Hexperience builds. Generally I have no issue posting them, but these were made while there were some issues in the code that I wouldn't want to propagate into user's model files.
We should probably setup a thread/forum where builds can be placed that would make it easy to prune old ones. Alternatively, maybe setup something that would make it easy to auto-build/upload new firmwares (semi)automatically
EDIT: Moved the builds to here:
www.deviationtx.com/forum/builds/1165-pre-v2-1-builds#4017
Last edit: 15 Dec 2012 19:13 by FDR.
15 Dec 2012 18:49 - 15 Dec 2012 18:52 #4019 by RugWarrior
Thank you for posting the latest builds! I also think that an own thread would make sense for the builds. And as I saw there is alredy a place under "Development"/"Builds" :)
Maybe you should move your new Thread over there?!
Last edit: 15 Dec 2012 18:52 by RugWarrior.
15 Dec 2012 19:12 #4020 by FDR
RugWarrior wrote: Thank you for posting the latest builds! I also think that an own thread would make sense for the builds. And as I saw there is alredy a place under "Development"/"Builds" :)
Sorry, it was me: moved to the wrong category.
Now it is there...
Time to create page: 0.069 seconds
