Waring: v2.0 is not reliable
08 Dec 2012 06:14 - 08 Dec 2012 06:15 #3772 by coaster
Replied by coaster on topic Waring: v2.0 is not reliable
only a minor, during the bind process (DEVO)
the battery indicator shows 8,9V, after the bind process
voltage is o.k. (4.6V)
cheers
Graziano
Last edit: 08 Dec 2012 06:15 by coaster.
08 Dec 2012 07:03 - 08 Dec 2012 07:03 #3773 by flint723
Replied by flint723 on topic Waring: v2.0 is not reliable
I can't get it to reboot with your fixed firmware. :) However I have been getting another issue, which is that when switching models, on any model above model 8, it will mess up the model list and highlighted area as pictured. It doesn't happen 100% of the time, only about 1 in 4 times of loading the model list. And it has to be on a model above 8. Protocol doesn't seem to matter. This also happened with original v2.0. But it doesn't seem to affect function, you can still pick whatever model you want. This is on devo 8s
Last edit: 08 Dec 2012 07:03 by flint723.
08 Dec 2012 07:17 #3774 by PhracturedBlue
Replied by PhracturedBlue on topic Waring: v2.0 is not reliable
coaster wrote: only a minor, during the bind process (DEVO)
Yeah, I know about that issue. I need to wait for the 1st ADC read to complete before drawing the page. It is easy enough to fix.
08 Dec 2012 07:23 #3775 by PhracturedBlue
flint723 wrote: I can't get it to reboot with your fixed firmware. :) However I have been getting another issue, which is that when switching models, on any model above model 8, it will mess up the model list and highlighted area as pictured. It doesn't happen 100% of the time, only about 1 in 4 times of loading the model list. And it has to be on a model above 8. Protocol doesn't seem to matter. This also happened with original v2.0. But it doesn't seem to affect function, you can still pick whatever model you want. This is on devo 8
Can you be more explicit about exactly how you replicate it? I can't seem to do so myself. are you using the buttons to navigate? is it only when you 1st enter the load screen or when you move the selection up or down?
Are you running any custom themes. the more info you can provide the better.
08 Dec 2012 07:42 #3776 by flint723
No custom anything, just v2.0 clean installed (and now your updated version), then I moved my models in that I had previously backed up. It happens when I am on model 9 or any model above 8 and I click the model switch button using the touchscreen (not buttons), then cancel. It can be done very fast, ~2 times per second at least. So I am not switching models, just loading the model select page and then hitting cancel. Even if it is on a "None" model it will do it. I have tried it extensively on all models below 9 and it has never happened on 1-8.
08 Dec 2012 09:03 - 08 Dec 2012 09:05 #3778 by vlad_vy
Replied by vlad_vy on topic Waring: v2.0 is not reliable
I can reproduce this effect. If after that I scroll down, will appear the next numbers of the list (more than 12). If I scroll up, the list shortened down to 7 models.
Last edit: 08 Dec 2012 09:05 by vlad_vy.
08 Dec 2012 10:12 #3780 by vlad_vy
With latest release stick calibration don't working. Throttle is at center, all sticks do not respond.
08 Dec 2012 13:38 - 08 Dec 2012 13:46 #3783 by domcars0
Replied by domcars0 on topic Waring: v2.0 is not reliable
I confirm what vlad_vy said about the latest (this night) PB release, also on Devo 10 ..After calibrate the sticks... they do not work anymore (nor the AUX4, AUX5)...
Here are the calibrate values of tx.ini file after calibration ;)
[calibrate1]
max=2095
min=2095
zero=2095
[calibrate2]
max=491
min=491
zero=491
[calibrate3]
max=2031
min=2031
zero=2031
[calibrate4]
max=2200
min=2200
zero=2200
[calibrate5]
max=2195
min=2195
zero=2195
[calibrate6]
max=1831
min=1831
zero=1831
Last edit: 08 Dec 2012 13:46 by domcars0.
08 Dec 2012 14:24 #3784 by RugWarrior
Replied by RugWarrior on topic Waring: v2.0 is not reliable
Same for my Devo 8S...
08 Dec 2012 14:26 #3785 by PhracturedBlue
Thanks. I've fixed the voltage display and calibration.
I've also fixed the model load issue.
The bug is triggered if the throttle was the last thing drawn before you enter the load page. So moving the throttle while entering the load page makes it easier to trigger. It also could be triggered in the emulator.
08 Dec 2012 14:28 - 15 Dec 2012 19:02 #3786 by PhracturedBlue
Here are updated builds
Last edit: 15 Dec 2012 19:02 by FDR.
08 Dec 2012 14:31 #3787 by Fredyp
Replied by Fredyp on topic Waring: v2.0 is not reliable
Sorry for my english
My Devo8s say "Telemetry is turned off"
Thank you for the fixing bug!
Fred.
08 Dec 2012 14:43 #3788 by PhracturedBlue
yeah. that is new. I'm going to change the deafult to 'On' for backwards compatibility.
You can enable telemetry for the moment by goingto the model page. pressing 'Devo' and switching it on.
08 Dec 2012 14:47 #3789 by vlad_vy
PB, can you check issue #167 with updated russian language file (issue #168)?
08 Dec 2012 16:04 #3794 by RugWarrior
Calibration with Devo 8S works now :)
08 Dec 2012 17:23 #3799 by flint723
Yep, all fixed. for me anyway.
08 Dec 2012 19:50 #3801 by magic_marty
Replied by magic_marty on topic Waring: v2.0 is not reliable
PhracturedBlue wrote: Here are updated builds
which one of the three is for the Devo8s?
thanks..
08 Dec 2012 19:53 #3802 by Hexperience
Replied by Hexperience on topic Waring: v2.0 is not reliable
The file names don't show completely in the post, but if you put hover your mouse over the links and look at your browser status bar you can see the complete file name.
Cheers
09 Dec 2012 15:58 #3821 by dado099
Replied by dado099 on topic Waring: v2.0 is not reliable
At the moment after a couple of days testing with various rx (all Walkera),
I found no bug at all.
Very good job PB !
Hope all others can give their feedback so you can build up a stable 2.1
Have a good fly ! :)
09 Dec 2012 17:31 #3826 by Joshua
Replied by Joshua on topic Waring: v2.0 is not reliable
I testet the new Version today with all my different modells.
No reboot, no other problems! ;)
Thanks for this update.
Time to create page: 0.073 seconds
