development:building_with_eclipse
development:building_with_eclipse [2016/04/15 19:10] PhracturedBlue created |
development:building_with_eclipse [2016/04/30 08:18] PhracturedBlue |
===== Building With Eclipse ===== | ===== Building With Eclipse ===== | ||
+ | **NOTE: It is now strongly recommended that you use Docker images to build Deviation. Instructions for building can be found [[development:docker | here]]** | ||
Thanks to xCometz for these instructions | Thanks to xCometz for these instructions | ||
- | ''Note: These instructions are based on building from HG. Deviation is now on github and the instructions need to be updated'' | + | **Note: These instructions are based on building from HG. Deviation is now on github and the instructions need to be updated** |
I hope this quick eclipse instruction can help. | I hope this quick eclipse instruction can help. |
development/building_with_eclipse.txt (11445 views) ยท Last modified: 2016/04/30 08:18 by PhracturedBlue
