development:setting_up_build_env [2016/04/30 07:45] PhracturedBlue |
- | Only the official embedded-arm build system is supported now | ||
- | Get the most recent release from here: | ||
- | https://launchpad.net/gcc-arm-embedded | ||
- | Current build version: gcc-arm-none-eabi-4_8-2013q4-20131204 | ||
- | 1) download and install the precompiled linux compiler from here: ''https://launchpad.net/gcc-arm-embedded'' | + | - download and install the precompiled linux compiler from here: https://launchpad.net/gcc-arm-embedded |
- | * Note that the only supported compiler for Deviation is gcc-arm-none-eabi-4_8-2013q4-20131204. You can find the link to this from the [[All Downloads | https://launchpad.net/gcc-arm-embedded/+download]] page. | + | * Note that the only supported compiler for Deviation is gcc-arm-none-eabi-4_8-2013q4-20131204. You can find the link to this from here: https://launchpad.net/gcc-arm-embedded/+download |
- | 2) Add the path to the 'bin' directory to your PATH | + | - Add the path to the 'bin' directory to your PATH |
- | 1) Download and install the precompiled windows compiler from here: ''https://launchpad.net/gcc-arm-embedded'' | + | - Download and install the precompiled windows compiler from here: https://launchpad.net/gcc-arm-embedded |
- | 2) Add path to 'bin' directory to your PATH (I like to put this into ~/.profile so it is there each time I start msys): ''export PATH=/mingw/stm32/bin:$PATH'' | + | - Add path to 'bin' directory to your PATH (I like to put this into ~/.profile so it is there each time I start msys): ''export PATH=/mingw/stm32/bin:$PATH'' |
- | 3) Ensure python is installed. If not install it from here: ''http://www.python.org/download/releases/2.7.3/'' | + | - Ensure python is installed. If not install it from here: http://www.python.org/download/releases/2.7.3/ |
- | 4) Add python to your msys path: ''export PATH="/c/<path to python>":$PATH'' | + | - Add python to your msys path: ''export PATH="/c/<path to python>":$PATH'' |
* For example: ''export PATH="/c/Program Files/Python27":$PATH)'' | * For example: ''export PATH="/c/Program Files/Python27":$PATH)'' | ||
- | ==== Builing the Windows binary on Linux ==== | + | ==== Building the Windows binary on Linux ==== |
First install fltk: | First install fltk: | ||
- | <code> | + | apt-get install mingw32 mingw32-binutils mingw32-runtime |
- | apt-get install mingw32 mingw32-binutils mingw32-runtime | + | <Download and unpack fltk source code> |
- | <Download and unpack fltk source code> | + | ./configure --disable-largefile --enable-localjpeg \ |
- | ./configure --disable-largefile --enable-localjpeg \ | + | |
--enable-localzlib --enable-localpng \ | --enable-localzlib --enable-localpng \ | ||
--disable-gl --host=i586-mingw32msvc \ | --disable-gl --host=i586-mingw32msvc \ | ||
--prefix=/opt/fltk-w32 | --prefix=/opt/fltk-w32 | ||
- | make | + | make |
- | sudo make install | + | sudo make install |
- | </code> | + | |
Next install portaudio: | Next install portaudio: | ||
- | <code> | + | <Download and unpack portaudio source code> |
- | <Download and unpack portaudio source code> | + | ./configure --prefix=/opt/portaudio-w32 |
- | ./configure --prefix=/opt/portaudio-w32 | + | make |
- | make | + | sudo make install |
- | sudo make install | + | |
- | </code> | + | |
==== Building the Windows binary on Windows ==== | ==== Building the Windows binary on Windows ==== | ||
Line 70: | Line 60: | ||
- | Finall, install Deviation: | + | Finally, install Deviation: |
* Download the source code for deviation. You'll need mercurial to keep track of changes (which will require installing python), but you can manually download a zip of the source from bitbucket.org/PhracturedBlue/deviation | * Download the source code for deviation. You'll need mercurial to keep track of changes (which will require installing python), but you can manually download a zip of the source from bitbucket.org/PhracturedBlue/deviation | ||
* cd ~/src | * cd ~/src | ||
+ | * Building the emulator is done by pre-pending 'emu_': ''make emu_devo8'' or ''make zip_emu_devo8'' | ||
development/setting_up_build_env.txt (24121 views) · Last modified: 2019/03/04 20:06 by csujun
