get_started_with_deviationtx [2016/06/30 12:41] Arnold [If you have a question...] |
Line 9: | Line 10: | ||
Line 16: | Line 17: | ||
Line 27: | Line 28: | ||
Line 37: | Line 38: | ||
* DSM2 | * DSM2 | ||
* DSMX | * DSMX | ||
Line 58: | Line 59: | ||
- | If you haven't found an answer for your particular question, just ask away in the [[http://www.deviationtx.com/forum|Forum]]. However, when you start a new topic, please select a category appropriate to your question! And only pick one to start with. Creating two threads just makes things confusing, and if it's in the wrong place that can be dealt with later. | + | The [[guides|Tutorials and How-Tos]] can also be helpful. |
get_started_with_deviationtx.txt (74763 views) · Last modified: 2020/01/31 12:43 by laurent_martin
