get_started_with_deviationtx [2017/03/16 09:25] thanh1516 [First you need a TX] |
- | \\devo 7e | + | |
- | ...if you don't have one already. The currently supported models include the 6, 6S, 7E. | + | ...if you don't have one already. The currently supported models include the 6, 6S, 7E, 8, 8S, 10, 12, 12S, 12E, F4, F7 and F12E, and you can read some opinions here: [[which_devo_tx_should_i_buy|Which Devo TX should I buy?]] |
Line 56: | Line 58: | ||
get_started_with_deviationtx.txt (72776 views) · Last modified: 2020/01/31 12:43 by laurent_martin
