hardware:devo8
hardware:devo8 [2016/04/20 07:26] (current) PhracturedBlue |
- | Devo 8 | ||
Line 14: | Line 12: | ||
+ | **TL:** Trim Left | ||
+ | **TR:** Trim Right | ||
+ | **TU:** Trim Up | ||
+ | **TD:** Trim down | ||
+ | ==== FCC Report ==== | ||
hardware/devo8.1460738983.txt.gz (104034 views) · Last modified: 2016/04/15 09:49 by PhracturedBlue
