hardware:devof12e
hardware:devof12e [2016/04/15 18:34] PhracturedBlue |
hardware:devof12e [2017/03/09 23:07] vlad_vy |
- | ===== Devo 10 Hardware Connections ===== | + | ===== Devo F12E Hardware Connections ===== |
The following documents the hardware inside the Devo-F12E transmitter | The following documents the hardware inside the Devo-F12E transmitter | ||
* MCU: [[http://www.st.com/internet/mcu/product/164492.jsp|STM32F103VCT6]] 256kB Flash, 48kB RAM 100pin package | * MCU: [[http://www.st.com/internet/mcu/product/164492.jsp|STM32F103VCT6]] 256kB Flash, 48kB RAM 100pin package | ||
* SPI Flash: [[http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CCwQFjAA&url=http%3A%2F%2Fwww.pctgroup.com.tw%2Fattachments%2Ffiles%2Ffiles%2F255_25VF512A-P.pdf&ei=LN2wUq6YDc7uoASrj4GYCw&usg=AFQjCNEUobGRb267XLDjKSpEVCCPasoWEA&sig2=qGo-PDtnqvy7ccj1-U3xaA&bvm=bv.58187178,d.cG|UPCT25VF512A]] 64kB SPI NOR Flash | * SPI Flash: [[http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CCwQFjAA&url=http%3A%2F%2Fwww.pctgroup.com.tw%2Fattachments%2Ffiles%2Ffiles%2F255_25VF512A-P.pdf&ei=LN2wUq6YDc7uoASrj4GYCw&usg=AFQjCNEUobGRb267XLDjKSpEVCCPasoWEA&sig2=qGo-PDtnqvy7ccj1-U3xaA&bvm=bv.58187178,d.cG|UPCT25VF512A]] 64kB SPI NOR Flash | ||
- | * LCD Display: [[http://www.deviationtx.com/media/kunena/attachments/1641/TW8816spec_10152007.pdf|Techwell TW8816]] Driver (640x480 panel). 12x18 characters, programmable font | + | * LCD Display: [[https://www.deviationtx.com/media/kunena/attachments/1641/TW8816spec_10152007.pdf|Techwell TW8816]] Driver (800x480 panel). 12x18 characters, programmable font |
* Voltage Regulator: [[http://aitendo3.sakura.ne.jp/aitendo_data/product_img/ic/power/MP1584EN/MP1584.pdf|MP1584EN]] Switching regulator | * Voltage Regulator: [[http://aitendo3.sakura.ne.jp/aitendo_data/product_img/ic/power/MP1584EN/MP1584.pdf|MP1584EN]] Switching regulator | ||
- | ^Pin ^Description ^ | + | ^Pin ^Description ^ |
|BOOT0 |CON2 | | |BOOT0 |CON2 | | ||
|NRST |Debugger (NRESET) | | |NRST |Debugger (NRESET) | | ||
- | | 0: (ADC123_0) | AUX 7 | | + | |0 (ADC123_0) |AUX 7 | |
- | | 4 (ADC12_4) | AUX 6 | | + | |4 (ADC12_4) |AUX 6 | |
- | | 5 (SPI1_SCK) | SPI Flash | | + | |5 (SPI1_SCK) |SPI Flash | |
- | | 6 (SPI1_MISO) | SPI Flash | | + | |6 (SPI1_MISO) |SPI Flash | |
- | | 7 (SPI1_MOSI) | SPI Flash | | + | |7 (SPI1_MOSI) |SPI Flash | |
- | | 9 (USART1_TX) | Trainer Rx | | + | |9 (USART1_TX) |Trainer Rx | |
- | | 10 (USART1_RX) | Trainer Tx | | + | |10 (USART1_RX) |Trainer Tx | |
- | | 0 (ADC12_8) | AUX 5 | | + | |0 (ADC12_8) |AUX 5 | |
- | | 1 | Backlight PWM control | | + | |1 |Backlight PWM control | |
- | | 2 (BOOT1) | SPI Flash Chip-Select | | + | |2 (BOOT1) |SPI Flash Chip-Select | |
- | | 6 | I2C1_SCL (LCD) | | + | |6 |I2C1_SCL (LCD) | |
- | | 7 | I2C1 SDA (LCD) | | + | |7 |I2C1 SDA (LCD) | |
- | | 12 (SPI2_NSS) | TxModule pin 1 | | + | |12 (SPI2_NSS) |TxModule pin 1 | |
- | | 13 (SPI2_SCK) | TxModule pin 3 | | + | |13 (SPI2_SCK) |TxModule pin 3 | |
- | | 14 (SPI2_MISO) | TxModule pin 9 | | + | |14 (SPI2_MISO) |TxModule pin 9 | |
- | | 15 (SPI2_MOSI) | TxModule pin 7 | | + | |15 (SPI2_MOSI) |TxModule pin 7 | |
- | | 0 (ADC123_IN_10) | AUX 4 | | + | |0 (ADC123_IN_10) |AUX 4 | |
- | | 1 (ADC123_IN_11) | Left Horizontal Stick | | + | |1 (ADC123_IN_11) |Left Horizontal Stick | |
- | | 2 (ADC123_IN_12) | Right Vertical Stick | | + | |2 (ADC123_IN_12) |Right Vertical Stick | |
- | | 3 (ADC123_IN_13) | Right Horizontal Stick | | + | |3 (ADC123_IN_13) |Right Horizontal Stick | |
- | | 4 (ADC12_IN_14) | Battery Voltage | | + | |4 (ADC12_IN_14) |Battery Voltage | |
- | | 5 (ADC12_IN_15) | Left Vertical Stick | | + | |5 (ADC12_IN_15) |Left Vertical Stick | |
- | | 6 | Gear Switch | | + | |6 |Gear Switch | |
- | | 7 | Elevator D/R Switch | | + | |7 |Elevator D/R Switch | |
- | | 8 | Rudder D/R Switch | | + | |8 |Rudder D/R Switch | |
- | | 9 | FMode 0 Switch | | + | |9 |FMode 0 Switch | |
- | | 10 | FMode 2 Switch | | + | |10 |FMode 2 Switch | |
- | | 11 | Aileron D/R Switch | | + | |11 |Aileron D/R Switch | |
- | | 12 | Mix 0 Switch | | + | |12 |Mix 0 Switch | |
- | | 13 | Mix 2 Switch | | + | |13 |Mix 2 Switch | |
- | | 2 | Vibrator | | + | |2 |Vibrator | |
- | | 8 | Video Channel 4 | | + | |8 |Video Channel 4 | |
- | | 10 | Video Channel 5 | | + | |10 |Video Channel 5 | |
- | | 7 | LCD Reset | | + | |7 |LCD Reset | |
- | | 8 | Video Channel 1 | | + | |8 |Video Channel 1 | |
- | | 9 | Video Channel 2 | | + | |9 |Video Channel 2 | |
- | | 10 | Video Channel 3 | | + | |10 |Video Channel 3 | |
- | | 11 | Video AV On/Off | | + | |11 |Video AV On/Off | |
- | | 12 | ??? E12,E13,E14 are related | | + | |12 |??? E12,E13,E14 are related | |
- | | 13 | ??? E12,E13,E14 are related | | + | |13 |??? E12,E13,E14 are related | |
- | | 14 | ??? E12,E13,E14 are related | | + | |14 |??? E12,E13,E14 are related | |
Line 97: | Line 97: | ||
- | ^E.2 | L- | Rudder Trim Left | Top Left Trim Down | NC | | + | ^E.2 |L- |Rudder Trim Left |Top Left Trim Down |NC | |
- | ^E.3 | Aileron Trim Right | Rudder Trim Right | Top Left Trim Up | Elevator Trim Up | | + | ^E.3 |Aileron Trim Right |Rudder Trim Right |Top Left Trim Up |Elevator Trim Up | |
- | ^E.4 | Aileron Trim Left | Ext | Top Right Trim Up | Throttle Trim Up | | + | ^E.4 |Aileron Trim Left |Ext |Top Right Trim Up |Throttle Trim Up | |
- | ^E.5 | Ent | UP+ | Top Right Trim Down | Elevator Trim Down | | + | ^E.5 |Ent |UP+ |Top Right Trim Down |Elevator Trim Down | |
- | ^E.6 | R+ | DN- | NC | Throttle Trim Down | | + | ^E.6 |R+ |DN- |NC |Throttle Trim Down | |
+ | ==== FCC Report ==== | ||
+ | FCCID: [[https://www.fcc.gov/general/fcc-id-search-page|S29 DEVO-F12E]] | ||
hardware/devof12e.txt (78821 views) · Last modified: 2017/03/09 23:10 by vlad_vy
