hardware:taranis_x9d
hardware:taranis_x9d [2016/04/15 18:50] PhracturedBlue created |
hardware:taranis_x9d [2016/04/20 07:33] PhracturedBlue |
+ | ~~TOC:3-4~~ | ||
===== Taranis X9D Hardware Connections ===== | ===== Taranis X9D Hardware Connections ===== | ||
The following documents the hardware inside the Taranis X9D transmitter | The following documents the hardware inside the Taranis X9D transmitter | ||
Line 9: | Line 10: | ||
- | ^Pin ^Description ^ | + | ^Pin ^Description ^ |
- | | 0 | Stick RV | | + | |0 |Stick RV | |
- | | 1 | Stick RH | | + | |1 |Stick RH | |
- | | 2 | Stick LH | | + | |2 |Stick LH | |
- | | 3 | Stick LV | | + | |3 |Stick LV | |
- | | 4 | Audio DAC (???) | | + | |4 |Audio DAC (???) | |
- | | 5 | Switch C- | | + | |5 |Switch C- | |
- | | 6 | POT L (Aux2) | | + | |6 |POT L (Aux2) | |
- | | 7 | PPM for external module | | + | |7 |PPM for external module | |
- | | 8 | Trainer plug detect | | + | |8 |Trainer plug detect | |
- | | 9 | USB Vin | | + | |9 |USB Vin | |
- | | 10 | PPM for FrSky Module | | + | |10 |PPM for FrSky Module | |
- | | 11 | USB Data- | | + | |11 |USB Data- | |
- | | 12 | USB Data+ | | + | |12 |USB Data+ | |
- | | 13 | SWDIO (Pads on P12.2) | | + | |13 |SWDIO (Pads on P12.2) | |
- | | 14 | SWCLK (Pads on P12.3) | | + | |14 |SWCLK (Pads on P12.3) | |
- | | 15 (SPI3 Enable) | I2S Audio WS (???) | | + | |15 (SPI3 Enable) |I2S Audio WS (???) | |
- | | 0 | POT R (Aux3) | | + | |0 |POT R (Aux3) | |
- | | 1 | Switch D- | | + | |1 |Switch D- | |
- | | 2 | ??? | | + | |2 |??? | |
- | | 3 | Switch E- | | + | |3 |Switch E- | |
- | | 4 | Switch E+ | | + | |4 |Switch E+ | |
- | | 5 | Switch A+ | | + | |5 |Switch A+ | |
- | | 6 (I2C SCL) | EEPROM SCL(???) | | + | |6 (I2C SCL) |EEPROM SCL(???) | |
- | | 7 (I2C SDA) | EEPROM SDA(???) | | + | |7 (I2C SDA) |EEPROM SDA(???) | |
- | | 8 | Backlight PWM | | + | |8 |Backlight PWM | |
- | | 9 (I2C WP) | EEPROM WP(???) | | + | |9 (I2C WP) |EEPROM WP(???) | |
- | | 10 | UART3 Tx | | + | |10 |UART3 Tx | |
- | | 11 | UART3 Rx | | + | |11 |UART3 Rx | |
- | | 12 (SPI2 CS) | SD Card ChipSelect | | + | |12 (SPI2 CS) |SD Card ChipSelect | |
- | | 13 (SPI2 SCK) | SD Card SCK | | + | |13 (SPI2 SCK) |SD Card SCK | |
- | | 14 (SPI2 MISO) | SD Card MISO | | + | |14 (SPI2 MISO) |SD Card MISO | |
- | | 15 (SPI2 MOSI) | SD Card MOSI | | + | |15 (SPI2 MOSI) |SD Card MOSI | |
- | | 0 | Voltage detect | | + | |0 |Voltage detect | |
- | | 1 | Buttom 'Trim RH -' | | + | |1 |Buttom 'Trim RH -' | |
- | | 2 | Buttom 'Trim RV +' | | + | |2 |Buttom 'Trim RV +' | |
- | | 3 | Buttom 'Trim RV -' | | + | |3 |Buttom 'Trim RV -' | |
- | | 4 | Slider L (Aux4) | | + | |4 |Slider L (Aux4) | |
- | | 5 | Slider R (Aux5) | | + | |5 |Slider R (Aux5) | |
- | | 6 | Power LED | | + | |6 |Power LED | |
- | | 7 | Heartbeat (???) | | + | |7 |Heartbeat (???) | |
- | | 8 | Trainer PPM In | | + | |8 |Trainer PPM In | |
- | | 9 | Trainer PPM Out | | + | |9 |Trainer PPM Out | |
- | | 10 (SPI3 SCK) | I2S_Audio SCK(???) | | + | |10 (SPI3 SCK) |I2S_Audio SCK(???) | |
- | | 11 | Audio DAC Mute(???) | | + | |11 |Audio DAC Mute(???) | |
- | | 12 (SPI3 SD) | I2S_Audio SD(???) | | + | |12 (SPI3 SD) |I2S_Audio SD(???) | |
- | | 13 | Buttom 'Trim RH +' | | + | |13 |Buttom 'Trim RH +' | |
- | | 14 | XTAL | | + | |14 |XTAL | |
- | | 15 | XTAL | | + | |15 |XTAL | |
- | | 0 | Power shutdown | | + | |0 |Power shutdown | |
- | | 1 | Power switch postition | | + | |1 |Power switch postition | |
- | | 2 | Button 'Exit' | | + | |2 |Button 'Exit' | |
- | | 3 | Button 'Page' | | + | |3 |Button 'Page' | |
- | | 4 | Sport Enable(???) | | + | |4 |Sport Enable(???) | |
- | | 5 | Sport Tx(???) | | + | |5 |Sport Tx(???) | |
- | | 6 | Sport Rx(???) | | + | |6 |Sport Rx(???) | |
- | | 7 | Button 'Menu' | | + | |7 |Button 'Menu' | |
- | | 8 | ??? | | + | |8 |??? | |
- | | 9 | SD Card Detect | | + | |9 |SD Card Detect | |
- | | 10 | LCD MOSI | | + | |10 |LCD MOSI | |
- | | 11 | LCD CLK | | + | |11 |LCD CLK | |
- | | 12 | LCD RST | | + | |12 |LCD RST | |
- | | 13 | LCD A0 | | + | |13 |LCD A0 | |
- | | 14 | LCD NCS | | + | |14 |LCD NCS | |
- | | 15 | N/C | | + | |15 |N/C | |
- | | 0 | Switch A- | | + | |0 |Switch A- | |
- | | 1 | Switch B+ | | + | |1 |Switch B+ | |
- | | 2 | Switch B- | | + | |2 |Switch B- | |
- | | 3 | Button 'Trim LH +' | | + | |3 |Button 'Trim LH +' | |
- | | 4 | Button 'Trim LH -' | | + | |4 |Button 'Trim LH -' | |
- | | 5 | Button 'Trim LV +' | | + | |5 |Button 'Trim LV +' | |
- | | 6 | Button 'Trim LV -' | | + | |6 |Button 'Trim LV -' | |
- | | 7 | Switch D+ | | + | |7 |Switch D+ | |
- | | 8 | Switch G- | | + | |8 |Switch G- | |
- | | 9 | Switch G+ | | + | |9 |Switch G+ | |
- | | 10 | Button 'Plus' | | + | |10 |Button 'Plus' | |
- | | 11 | Button 'Enter' | | + | |11 |Button 'Enter' | |
- | | 12 | Button 'Minus' | | + | |12 |Button 'Minus' | |
- | | 13 | Switch H | | + | |13 |Switch H | |
- | | 14 | Switch F | | + | |14 |Switch F | |
- | | 15 | Switch C+ | | + | |15 |Switch C+ | |
==== Pad P12 ==== | ==== Pad P12 ==== | ||
- | | 1 | 3.3V | | + | |1 |3.3V | |
- | | 2 | PA13 | | + | |2 |PA13 | |
- | | 3 | PA14 | | + | |3 |PA14 | |
- | | 4 | GND | | + | |4 |GND | |
==== Externaml PPM Module (Pin 1 at bottom) ==== | ==== Externaml PPM Module (Pin 1 at bottom) ==== | ||
- | | 1 | SPORT | | + | |1 |SPORT | |
- | | 2 | GND | | + | |2 |GND | |
- | | 3 | ??? | | + | |3 |??? | |
- | | 4 | Heartbeat | | + | |4 |Heartbeat | |
- | | 5 | ??? | | + | |5 |??? | |
+ | ==== FCC Report ==== | ||
+ | FCCID: [[https://www.fcc.gov/general/fcc-id-search-page|XYF X91216DK]] |
hardware/taranis_x9d.txt (74723 views) · Last modified: 2016/04/20 07:33 by PhracturedBlue
