model5
model5 [2018/01/16 20:00] MikeNH |
model5 [2018/01/16 20:09] MikeNH |
- | NOTE: The formatting is correct only when in Edit made. I don;t know why.\\ | ||
name=Babyhawk\\ | name=Babyhawk\\ | ||
mixermode=Advanced\\ | mixermode=Advanced\\ | ||
Line 8: | Line 6: | ||
num_channels=12\\ | num_channels=12\\ | ||
tx_power=150mW\\ | tx_power=150mW\\ | ||
- | [protocol_opts] | + | [protocol_opts]\\ |
- | Failsafe=Hold | + | Failsafe=Hold\\ |
- | AD2GAIN=100 | + | AD2GAIN=100\\ |
- | Freq-Fine=0 | + | Freq-Fine=0\\ |
- | Format=FCC | + | Format=FCC\\ |
- | RSSIChan=None | + | RSSIChan=None\\ |
- | S.PORT Out=Disabled | + | S.PORT Out=Disabled\\ |
- | [channel1] | + | [channel1]\\ |
- | reverse=1 | + | reverse=1\\ |
- | template=simple | + | template=simple\\ |
- | [mixer] | + | [mixer]\\ |
- | src=AIL | + | src=AIL\\ |
- | dest=Ch1 | + | dest=Ch1\\ |
- | [channel2] | + | [channel2]\\ |
- | src=ELE | + | src=ELE\\ |
- | dest=Ch2 | + | dest=Ch2\\ |
- | [channel3] | + | [channel3]\\ |
- | src=THR | + | src=THR\\ |
- | dest=Ch3 | + | dest=Ch3\\ |
- | [channel4] | + | [channel4]\\ |
- | src=RUD | + | src=RUD\\ |
- | dest=Ch4 | + | dest=Ch4\\ |
- | [channel5] | + | [channel5]\\ |
- | src=HOLD1 | + | src=HOLD1\\ |
- | dest=Ch5 | + | dest=Ch5\\ |
- | curvetype=min/max | + | curvetype=min/max\\ |
- | points=0 | + | points=0\\ |
- | [channel6] | + | [channel6]\\ |
- | src=FMODE1 | + | src=FMODE1\\ |
- | dest=Ch6 | + | dest=Ch6\\ |
- | [channel7] | + | [channel7]\\ |
- | max=100 | + | max=100\\ |
- | scalar-=100 | + | scalar-=100\\ |
- | min=-100 | + | min=-100\\ |
- | src=Virt1 | + | src=Virt1\\ |
- | dest=Ch7 | + | dest=Ch7\\ |
- | curvetype=expo | + | curvetype=expo\\ |
- | points=0,0 | + | points=0,0\\ |
- | [channel8] | + | [channel8]\\ |
- | src=Virt2 | + | src=Virt2\\ |
- | dest=Ch8 | + | dest=Ch8\\ |
- | [channel9] | + | [channel9]\\ |
- | src=Virt3 | + | src=Virt3\\ |
- | dest=Ch9 | + | dest=Ch9\\ |
- | curvetype=3point | + | curvetype=3point\\ |
- | points=0,0,0 | + | points=0,0,0\\ |
- | [channel10] | + | [channel10]\\ |
- | src=Virt4 | + | src=Virt4\\ |
- | dest=Ch10 | + | dest=Ch10\\ |
- | [virtchan1] | + | [virtchan1]\\ |
- | name=Modes | + | name=Modes\\ |
- | [virtchan2] | + | [virtchan2]\\ |
- | name=Turtle | + | name=Turtle\\ |
- | [virtchan3] | + | [virtchan3]\\ |
- | name=PIDs 1 | + | name=PIDs 1\\ |
- | [virtchan4] | + | [virtchan4]\\ |
- | name=PIDs 2 | + | name=PIDs 2\\ |
- | [trim1] | + | [trim1]\\ |
- | pos=TRIMLV- | + | pos=TRIMLV-\\ |
- | neg=TRIMLV+ | + | neg=TRIMLV+\\ |
- | step=190 | + | step=190\\ |
- | switch=Virt1 | + | switch=Virt1\\ |
- | value=100,0,0 | + | value=100,0,0\\ |
- | [trim2] | + | [trim2]\\ |
- | pos=TRIMRV+ | + | pos=TRIMRV+\\ |
- | neg=TRIMRV- | + | neg=TRIMRV-\\ |
- | step=191 | + | step=191\\ |
- | switch=Virt2 | + | switch=Virt2\\ |
- | value=-100,0,0 | + | value=-100,0,0\\ |
- | [trim3] | + | [trim3]\\ |
- | src=Ch9 | + | src=Ch9\\ |
- | pos=TRIMLH+ | + | pos=TRIMLH+\\ |
- | neg=TRIMLH- | + | neg=TRIMLH-\\ |
- | switch=Virt3 | + | switch=Virt3\\ |
- | [trim4] | + | [trim4]\\ |
- | pos=TRIMRH- | + | pos=TRIMRH-\\ |
- | neg=TRIMRH+ | + | neg=TRIMRH+\\ |
- | switch=Virt4 | + | switch=Virt4\\ |
- | [timer1] | + | [timer1]\\ |
- | [timer2] | + | [timer2]\\ |
- | type=countdown | + | type=countdown\\ |
- | time=300 | + | time=300\\ |
- | [safety] | + | [safety]\\ |
- | Auto=min | + | Auto=min\\ |
- | [gui-128x64] | + | [gui-128x64]\\ |
- | V-trim=59,10,0 | + | V-trim=59,10,0\\ |
- | H-trim=5,59,3 | + | H-trim=5,59,3\\ |
- | V-trim=65,10,0 | + | V-trim=65,10,0\\ |
- | H-trim=74,59,4 | + | H-trim=74,59,4\\ |
- | Small-box=2,22,Ch3 | + | Small-box=2,22,Ch3\\ |
- | Small-box=2,31,Timer1 | + | Small-box=2,31,Timer1\\ |
- | Small-box=2,40,Timer2 | + | Small-box=2,40,Timer2\\ |
- | Model=75,20 | + | Model=75,20\\ |
- | Battery=102,1 | + | Battery=102,1\\ |
- | Toggle=4,10,64,1,0,Ch7 | + | Toggle=4,10,64,1,0,Ch7\\ |
- | Toggle=22,10,0,4,0,None | + | Toggle=22,10,0,4,0,None\\ |
- | Toggle=31,10,0,70,0,Ch8 | + | Toggle=31,10,0,70,0,Ch8\\ |
- | TxPower=102,7 | + | TxPower=102,7\\ |
- | quickpage1=Telemetry monitor | + | quickpage1=Telemetry monitor\\ |
model5.txt (110560 views) · Last modified: 2018/01/16 20:09 by MikeNH
