playground:playground
playground:playground [2017/10/15 18:39] MikeNH [Sandbox page for testing formatting, etc] |
- | == Simple steps to create guides such as Tutorials or How-Tos == | ||
- | Here's links to references for **[[https://www.dokuwiki.org/page| creating]]** and **[[wiki:syntax|formatting]]** Wiki documents.\\ | ||
- | These simple steps are only to create a new internal document. Here we go... \\ | ||
- | 3 - Choose Edit in either the Tutorials or How-Tos section. \\ | ||
- | 4 - Using the following syntax (without quotes), add the text for the new link: | ||
- | "* [[The title for my new document]]" | ||
- | 5 - Save the document and you'll see the link in red text. \\ | ||
- | 6 - Clicking the link will bring you to the new page you are about to populate. \\ |
playground/playground.1508117992.txt.gz (49821 views) · Last modified: 2017/10/15 18:39 by MikeNH
