rf_module_installation
rf_module_installation [2016/04/15 08:02] FDR [Modules] |
rf_module_installation [2016/04/15 12:05] FDR [Adding External Modules to Your Deviation Transmitter] |
The Deviation firmware implements several protocols that the Devo series radios do not have the necessary hardware to support. To enable these protocols, it is necessary to install additional 2.4GHz transceiver modules. The following modules are supported: | The Deviation firmware implements several protocols that the Devo series radios do not have the necessary hardware to support. To enable these protocols, it is necessary to install additional 2.4GHz transceiver modules. The following modules are supported: |
rf_module_installation.txt (14171 views) ยท Last modified: 2017/01/23 00:30 by FDR
