rf_module_installation
rf_module_installation [2016/04/14 19:49] PhracturedBlue |
rf_module_installation [2017/01/23 00:30] (current) FDR link |
//NOTE: Read through this entire manual before starting work. Make sure you understand what is needed and how to do it. Also, this procedure will void the warranty of your Devo transmitter in the process of implementing this modification.// | //NOTE: Read through this entire manual before starting work. Make sure you understand what is needed and how to do it. Also, this procedure will void the warranty of your Devo transmitter in the process of implementing this modification.// | ||
Line 23: | Line 24: | ||
- | * Devo8 (and Devo6, Devo10, Devo12): [[Devo8]] | + | * [[rf_module_installation:Devo8|Devo8 (and Devo6, Devo10, Devo12)]] |
- | * Devo7e: [[Devo7e]] | + | * [[rf_module_installation:Devo7e|Devo7e]] |
rf_module_installation.1460688574.txt.gz (13680 views) · Last modified: 2016/04/14 19:49 by PhracturedBlue
