start [2016/04/17 01:25] FDR [Development] |
start [2020/08/18 02:45] kestel [Hardware & Modifications] |
+ | * Read the manual | ||
+ | === Voice output === | ||
- | ===== List of Example Model Configurations ===== | + | === Change SPI Flash Chip === |
- | Here is a list of model files that have been submitted by the DeviationTx forum users: [[model_config]] | + | [[spiflash| Supported SPI Flash Chips]] |
start.txt (70005 views) · Last modified: 2020/08/18 02:45 by kestel
