supported_models
supported_models [2018/10/27 17:10] hexfet Add Quadrone |
supported_models [2019/03/12 21:06] (current) Higgins |
Line 285: | Line 285: | ||
|XK |[[https://www.deviationtx.com/forum/builds/5569-xk-k110-s-fhss-build-for-devo-7e-and-devo-10|K120]] |CP |[[modulelist:CC2500]] |[[protocol:S-FHSS]] |2016/04/13 | | | |XK |[[https://www.deviationtx.com/forum/builds/5569-xk-k110-s-fhss-build-for-devo-7e-and-devo-10|K120]] |CP |[[modulelist:CC2500]] |[[protocol:S-FHSS]] |2016/04/13 | | | ||
|XK |[[https://www.deviationtx.com/forum/builds/5569-xk-k110-s-fhss-build-for-devo-7e-and-devo-10|A600]] |Plane |[[modulelist:CC2500]] |[[protocol:S-FHSS]] |2016/04/13 | Would NOT bind to T8SG | | |XK |[[https://www.deviationtx.com/forum/builds/5569-xk-k110-s-fhss-build-for-devo-7e-and-devo-10|A600]] |Plane |[[modulelist:CC2500]] |[[protocol:S-FHSS]] |2016/04/13 | Would NOT bind to T8SG | | ||
+ | |XK |A800 |Plane |[[modulelist:NRF24L01]] |[[protocol:KN]] |2019/03/13 | Select 'WLToys' in protocol options; Worked with T8SG; Thanks to Albert Kim [[https://youtu.be/WCdqvSzSxdg?t=779]] | | ||
|XK |[[https://www.deviationtx.com/forum/builds/5569-xk-k110-s-fhss-build-for-devo-7e-and-devo-10?start=80#47690|X100]] |Quad |[[modulelist:CC2500]] |[[protocol:S-FHSS]] |2016/05/04 | | | |XK |[[https://www.deviationtx.com/forum/builds/5569-xk-k110-s-fhss-build-for-devo-7e-and-devo-10?start=80#47690|X100]] |Quad |[[modulelist:CC2500]] |[[protocol:S-FHSS]] |2016/05/04 | | | ||
- | |XK |[[http://www.rcgroups.com/forums/showthread.php?t=2536068|X250]] |Quad |[[modulelist:NRF24L01]] |[[protocol:V202]] |2016/01/31 | | | + | |XK |[[http://www.rcgroups.com/forums/showthread.php?t=2536068|X250]] |Quad |[[modulelist:NRF24L01]] |[[protocol:V202]] |2016/01/31 | also known as Revell Quadrotox | |
|YI ZHAN |[[https://www.deviationtx.com/forum/protocol-development/5292-yi-zhan-i6s-capture|i6S]] |Hexa |[[modulelist:NRF24L01]] |[[protocol:MT99XX]] |2016/02/06 |Select "i6S" format option, warning: only 1 hardcoded TX ID | | |YI ZHAN |[[https://www.deviationtx.com/forum/protocol-development/5292-yi-zhan-i6s-capture|i6S]] |Hexa |[[modulelist:NRF24L01]] |[[protocol:MT99XX]] |2016/02/06 |Select "i6S" format option, warning: only 1 hardcoded TX ID | | ||
|YI ZHAN |[[http://www.rcgroups.com/forums/showthread.php?t=2204427|X4]] |Quad |[[modulelist:NRF24L01]] |[[protocol:V202]] |2014/06/20 | | | |YI ZHAN |[[http://www.rcgroups.com/forums/showthread.php?t=2204427|X4]] |Quad |[[modulelist:NRF24L01]] |[[protocol:V202]] |2014/06/20 | | |
supported_models.1540685430.txt.gz (40781 views) ยท Last modified: 2018/10/27 17:10 by hexfet
