transmitter:devo7e
transmitter:devo7e [2016/05/08 08:24] silpstream |
transmitter:devo7e [2017/01/23 00:39] FDR https |
- | ==== Features ==== | + | *[[https://youtu.be/7hvjtHtRFXg?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Introduction to the Devo 7E]] by SeBy DocKy |
+ | ^ Features || | ||
Line 19: | Line 23: | ||
^ USB Upgradable | Yes | | ^ USB Upgradable | Yes | | ||
+ | ==== Installing DeviationTx ==== | ||
+ | Start by reading the Devo 7E [[https://www.deviationtx.com/user-manual/user-manual-7e-10|manual]]. | ||
+ | *[[https://youtu.be/2oqwpJJWssw?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|DeviationTX Installation]] by SeBy DocKy | ||
+ | == Disassembly == | ||
+ | *[[http://www.hacksmods.com/2013/04/walkera-devo-7e-transmitter-deviationx-flysky-hubsan-mod/|Devo 7E DeviationTx Flysky/Hubsan Mod]] by hacksmods.com | ||
+ | *[[https://youtu.be/u1SPgG2vWiE?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E nRF24L01 mod]] by SeBy DocKy | ||
+ | *[[https://youtu.be/0oXjk_oQsE8?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E CC2500 mod]] by SeBy DocKy | ||
+ | == Add Power-on LEDs == | ||
+ | == USB Charge Mod == | ||
- | == Add a Power-on LED == | + | ==== Hardware Information ==== |
transmitter/devo7e.txt (90555 views) · Last modified: 2019/02/22 15:39 by PhracturedBlue
