transmitter:devo7e
transmitter:devo7e [2016/05/08 13:09] silpstream Add info |
transmitter:devo7e [2019/02/22 15:39] PhracturedBlue |
Line 24: | Line 26: | ||
+ | == Disassembly == | ||
- | Alternatively you can [[building_the_multi-module|build]] the [[multimod|MultiModule]] instead. With the MultiModule, you will not need to solder to the processor pin and still use all 4 modules. | + | Alternatively you can [[:building_the_multi-module|build]] the [[modulelist:multimod|MultiModule]] instead. With the MultiModule, you will not need to solder to the processor pin and still use all 4 modules. |
- | The process is very well documented in the wiki page "[[rf_module_installation|RF Module Installation]]". | + | The process is very well documented in the wiki page "[[:rf_module_installation|RF Module Installation]]". |
Line 75: | Line 129: | ||
- | *[[hardware:devo7e|Devo 7E Hardware & Connections]] | + | |
transmitter/devo7e.txt (90700 views) · Last modified: 2019/02/22 15:39 by PhracturedBlue
