transmitter:devo7e
transmitter:devo7e [2016/05/09 08:16] silpstream |
transmitter:devo7e [2019/02/22 15:39] PhracturedBlue |
Line 27: | Line 27: | ||
==== Installing DeviationTx ==== | ==== Installing DeviationTx ==== | ||
Line 58: | Line 58: | ||
*[[https://youtu.be/u1SPgG2vWiE?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E nRF24L01 mod]] by SeBy DocKy | *[[https://youtu.be/u1SPgG2vWiE?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E nRF24L01 mod]] by SeBy DocKy | ||
*[[https://youtu.be/0oXjk_oQsE8?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E CC2500 mod]] by SeBy DocKy | *[[https://youtu.be/0oXjk_oQsE8?list=PLuuKkV7OPWOjqvKgUAfVEZlDdKmVZUOC7|Devo7E CC2500 mod]] by SeBy DocKy | ||
This will modify the stock RF module for full range. It requires removal of the shield and bypassing of a diode within module. Various methods for doing the bypass exists, so read through the tutorials and decide which you want to try. | This will modify the stock RF module for full range. It requires removal of the shield and bypassing of a diode within module. Various methods for doing the bypass exists, so read through the tutorials and decide which you want to try. | ||
- | *[[http://www.deviationtx.com/forum/3-feedback-questions/1439-removing-shield-and-diode-7e-for-better-reach|Removing shield and diode 7E for better reach]] by Mullson in our forum | + | *[[https://www.deviationtx.com/forum/3-feedback-questions/1439-removing-shield-and-diode-7e-for-better-reach|Removing shield and diode 7E for better reach]] by Mullson in our forum |
Line 72: | Line 73: | ||
This modification will add two 2-way switches labeled "SW A" and "SW B". | This modification will add two 2-way switches labeled "SW A" and "SW B". | ||
- | *[[http://www.deviationtx.com/forum/how-to/1436-add-two-switches-to-the-devo-7e|Add Two switches to the Devo 7E]] by cmpang in our forum | + | *[[https://www.deviationtx.com/forum/how-to/1436-add-two-switches-to-the-devo-7e|Add Two switches to the Devo 7E]] by cmpang in our forum |
Line 78: | Line 79: | ||
*[[http://www.rcgroups.com/forums/showthread.php?t=2468549|Adding Two 3-position Switches]] by straferr on rcgroups.com | *[[http://www.rcgroups.com/forums/showthread.php?t=2468549|Adding Two 3-position Switches]] by straferr on rcgroups.com | ||
*[[https://youtu.be/IKif67S_pzs|3x2 Switches Mod]] by SeBy DocKy | *[[https://youtu.be/IKif67S_pzs|3x2 Switches Mod]] by SeBy DocKy | ||
The trainer port can be hijacked for an arduino to provide PPM signals from nearly any combination of switches and potentiometers. This modification effectively takes over the trainer port by mimicking a 2nd connected transmitter and injects PPM signal to the channels. Note that once you do this mod, you will not be able to connect another transmitter to the trainer port. | The trainer port can be hijacked for an arduino to provide PPM signals from nearly any combination of switches and potentiometers. This modification effectively takes over the trainer port by mimicking a 2nd connected transmitter and injects PPM signal to the channels. Note that once you do this mod, you will not be able to connect another transmitter to the trainer port. | ||
*[[http://www.rcgroups.com/forums/showthread.php?t=2481981|Extra Potentiometer and Switch Inputs for Devo TX]] by JW57RC on rcgroups.com | *[[http://www.rcgroups.com/forums/showthread.php?t=2481981|Extra Potentiometer and Switch Inputs for Devo TX]] by JW57RC on rcgroups.com | ||
- | *[[http://www.deviationtx.com/forum/7-development/4442-extra-inputs-for-devo-tx-s?limitstart=0|Extra inputs for Devo Tx's]] by mwm in our forum | + | *[[https://www.deviationtx.com/forum/7-development/4442-extra-inputs-for-devo-tx-s?limitstart=0|Extra inputs for Devo Tx's]] by mwm in our forum |
Line 93: | Line 97: | ||
Swap out to a higher capacity LiPo battery. Search around as there are now few manufacturers that make a LiPo specifically for the Devo 7E. | Swap out to a higher capacity LiPo battery. Search around as there are now few manufacturers that make a LiPo specifically for the Devo 7E. | ||
*[[http://www.rcgroups.com/forums/showpost.php?p=28700856&postcount=3|Turnigy nano-tech in Devo 7E]] by Fyathyrio on rcgroups.com | *[[http://www.rcgroups.com/forums/showpost.php?p=28700856&postcount=3|Turnigy nano-tech in Devo 7E]] by Fyathyrio on rcgroups.com | ||
- | *[[http://www.deviationtx.com/forum/how-to/1455-battery-mod-devo7e|Battery Mod Devo 7E]] by Usjak in our forum | + | *[[https://www.deviationtx.com/forum/how-to/1455-battery-mod-devo7e|Battery Mod Devo 7E]] by Usjak in our forum |
Adding higher power handling regulators for the extra load due to the RF module upgrades. | Adding higher power handling regulators for the extra load due to the RF module upgrades. | ||
- | *[[http://www.deviationtx.com/forum/6-general-discussions/2910-devo-7e-a7105pa-range-mod-current-draw?start=20#24372|AMS1117 Replacement Regulator]] by Fernandez in our forum | + | *[[https://www.deviationtx.com/forum/6-general-discussions/2910-devo-7e-a7105pa-range-mod-current-draw?start=20#24372|AMS1117 Replacement Regulator]] by Fernandez in our forum |
- | *[[http://www.deviationtx.com/forum/6-general-discussions/5307-problem-with-overvolted-devo7e#43231|Pololu 3.3V Step-Up/Step-Down Voltage Regulator]] by Fernandez in our forum | + | *[[https://www.deviationtx.com/forum/6-general-discussions/5307-problem-with-overvolted-devo7e#43231|Pololu 3.3V Step-Up/Step-Down Voltage Regulator]] by Fernandez in our forum |
Line 129: | Line 133: | ||
transmitter/devo7e.txt (89427 views) · Last modified: 2019/02/22 15:39 by PhracturedBlue
