Countdown to release [updated 2012-08-15]
31 Aug 2012 23:25 #1317 by leloup
Replied by leloup on topic Countdown to release [updated 2012-08-15]
If you want, i can help your project with french translations and range check. I have walkera 2801 pro to compare and a lot of rx2801 and obviously a Devo 8s.
01 Sep 2012 01:37 #1318 by magic_marty
Replied by magic_marty on topic Countdown to release [updated 2012-08-15]
looks like a lot more progress has been made.Any info on a possible release date?
thanks a bunch...:)
01 Sep 2012 02:10 #1320 by PhracturedBlue
Replied by PhracturedBlue on topic Countdown to release [updated 2012-08-15]
Well, I just had to do major surgery to make the trims work properly and to support >100% throw. Those were the last issues I had on my plate before release (there are lots of other things that need doing, but I'm planning to defer them until after the 1st release is done). So now it is mostly a matter of finding all the bugs I just introduced, and testing that the code actually works as intended on all transmitters. I'll probably be doing some of that this weekend, but it'll take time to find the bugs, and if there are any unexpected surprises (like the mixer changes don't actually address our needs).
So yes, we are getting closer.
01 Sep 2012 02:19 #1321 by PhracturedBlue
leloup wrote: Hi,
Thanks for the offer. The string list is not 100% final, but it is getting pretty close, and is sufficient for translation I think.
Doing so is pretty easy.
First download one of the files in this dir (lang1 is Hungarian, lang2 is German) to use as a reference:
bitbucket.org/PhracturedBlue/deviation/s.../filesystem/language
Then translate each line that starts with a ':'
The syntax is that the English line (with a leading colon) comes 1st, and the translated string is the next line. Do not modify the English line!
if you see '\n' it indicates a new-line (you don't need to keep these in the same place, but you need the same number of them)
If you see special characters ('%s' or '%d') these indicate that another string or integer will be substituted at this point. these must be preserved as well.
The output file must be in UTF-8 format. The current font should support virtually all European languages.
When you are happy, you can attach your file to a post here, or you can file a ticket on bitbucket with your changes.
03 Sep 2012 18:53 #1353 by FDR
From the slowed down traffic and no bugs it seems the release is close! ;)
03 Sep 2012 20:43 #1355 by PhracturedBlue
FDR wrote: From the slowed down traffic and no bugs it seems the release is close! ;)
Hsve you tried the new release with your CP100? One of the things i ws waiting for is whether the 2401 code is working
04 Sep 2012 04:28 #1357 by FDR
It works, but since my CB100 is really sick, I cannot confirm how good is it.
04 Sep 2012 04:35 #1358 by PhracturedBlue
FDR wrote: It works, but since my CB100 is really sick, I cannot confirm how good is it.
Ok, well, I'll likely do the release in the next few days then. I need to clean up the documentation 1st.
05 Sep 2012 21:10 - 05 Sep 2012 22:24 #1366 by leloup
French translation :-)
Last edit: 05 Sep 2012 22:24 by leloup.
05 Sep 2012 21:24 #1367 by PhracturedBlue
leloup wrote: French translation :-)
Thanks, but that is definitely not utf8 :)
05 Sep 2012 22:28 #1368 by leloup
Sorry, it's corrected.
06 Sep 2012 00:52 #1369 by PhracturedBlue
I've merged it after some minor fixup. Thanks.
06 Sep 2012 03:47 - 07 Sep 2012 03:56 #1371 by PhracturedBlue
I've spent some time updating the User's Manual. Take a look and let me know what you think
File Attachment:
File Name: DeviationU...nual.pdf
File Size:426 KB
Last edit: 07 Sep 2012 03:56 by PhracturedBlue.
06 Sep 2012 04:10 #1372 by magic_marty
looks great! has a lot more info in it..
06 Sep 2012 11:22 - 06 Sep 2012 11:34 #1375 by FDR
Cool! Nice job... ;)
There are only a few minor issues:
- missing letter on page 3 last row;
- mixed capitals in the protocol binding table;
- sound.ini is missing from the directory structure's table;
- overview mentions telemetry as possible data on the main page;
- does the battery level still have graphical indication, as the main page legend states? (BTW telemetry appears there too);
- the next is a bit overstatement: "The number of boxes, their size and location, and their contents can all be controlled from here.";
- there is a reference error on the mixer list that supposed to refer to the model page;
- you could mention, that clicking on the curve opens the curve editor too;
- missing space: "COL Invoptions";
Of course there might be more, but I found just these...
This documentation is lightyears ahead of Walkera's user manuals! :lol:
Last edit: 06 Sep 2012 11:34 by FDR.
07 Sep 2012 00:37 #1378 by rototophe
Replied by rototophe on topic Countdown to release [updated 2012-08-15]
PhracturedBlue wrote: I've spent some time updating the User's Manual. Take a look and let me know what you think
The documentation looks real good. It is quite clear, complete and straight forward. And as FDR stated, it is clearer and more complete that what comes with the Tx when you buy it from the manufacturer.
The explanations and examples for the mixer given at the end of the document are very welcome and dispel some potential confusion about using the mixer.
07 Sep 2012 03:56 #1381 by PhracturedBlue
I've updated the document with FDR's feedback as well as new capabilities and a section describing the predefined-templates
07 Sep 2012 04:53 - 07 Sep 2012 04:53 #1382 by FDR
Where is it? I did not find...
Last edit: 07 Sep 2012 04:53 by FDR.
07 Sep 2012 05:08 #1385 by PhracturedBlue
I edited the previous post with the updated doc.
07 Sep 2012 14:08 #1386 by FDR
OK, I've updated the one in the downloads with it, and put it into the menu too...
How close is the release?
Time to create page: 0.062 seconds
