adding_3_position_virtual_switch_to_devo_7e
adding_3_position_virtual_switch_to_devo_7e [2017/10/15 17:11] MikeNH |
adding_3_position_virtual_switch_to_devo_7e [2017/10/24 19:25] (current) MikeNH |
Line 28: | Line 28: | ||
The title of the switch can be changed to something more meaningful such as FMode if it is to be used for Flight Modes. In the ground control software use the normal channel configuration to assign behavior. | The title of the switch can be changed to something more meaningful such as FMode if it is to be used for Flight Modes. In the ground control software use the normal channel configuration to assign behavior. | ||
+ | UPDATE: | ||
+ | I've recently added GPS to my quad so there is a need for even more flight modes. Adding a 5 position switch turns out to be very simple. In step 2 above, change Trim Step = 100 to Trim Step = 50. So now the tx output is +100, +50, 0, -50, -100. | ||
adding_3_position_virtual_switch_to_devo_7e.txt (14670 views) ยท Last modified: 2017/10/24 19:25 by MikeNH
