development:building_on_windows [2016/04/15 19:03] PhracturedBlue created |
development:building_on_windows [2016/04/30 08:17] PhracturedBlue |
- | ==== Install MingW ==== | + | **NOTE: It is now strongly recommended that you use Docker images to build Deviation. Instructions for building can be found [[development:docker | here]]** |
- | * [[http://sourceforge.net/projects/mingw/files/Installer/mingw-get-inst/mingw-get-inst-20120426/mingw-get-inst-20120426.exe/download||Download]] the mingw installer | + | |
+ | ''Note, these instructions may be out of date. Please help to make them current'' | ||
+ | ==== Install MinGW ==== | ||
+ | * [[http://sourceforge.net/projects/mingw/files/Installer/mingw-get-inst/mingw-get-inst-20120426/mingw-get-inst-20120426.exe/download|Download the MinGW installer]] | ||
Line 15: | Line 18: | ||
* cd src | * cd src | ||
Line 26: | Line 29: | ||
* cd ~/src | * cd ~/src | ||
Line 34: | Line 37: | ||
==== Running Emulator ==== | ==== Running Emulator ==== | ||
- | If everything goes well, you can now do: '''./emu_devo8.exe''' | + | If everything goes well, you can now do: ''./emu_devo8.exe'' |
==== MSYS notes ==== | ==== MSYS notes ==== | ||
Your 'home' dir will be at C:\MinGW\msys\1.0\home\<user> | Your 'home' dir will be at C:\MinGW\msys\1.0\home\<user> |
development/building_on_windows.txt (114439 views) · Last modified: 2016/04/30 08:17 by PhracturedBlue
