faq [2016/04/15 08:46] FDR [Can you answer a question about my stock Devo transmitter?] |
Line 22: | Line 22: | ||
Line 37: | Line 37: | ||
Line 53: | Line 52: | ||
- | A lot of TX experts are here, so probably yes. Ask your question in the [[http://www.deviationtx.com/forum/stock-firmware-help|Stock Firmware Help]] forum. However keep in mind, that the users of this site primarily use deviation on their transmitters, and might not remember all the stock settings, so you might be better to ask your questions in a generic modeller forum, like the [[http://www.rcgroups.com|RCGroups]]. | + | A lot of TX experts are here, so probably yes. Ask your question in the [[https://www.deviationtx.com/forum/stock-firmware-help|Stock Firmware Help]] forum. However keep in mind, that the users of this site primarily use deviation on their transmitters, and might not remember all the stock settings, so you might be better to ask your questions in a generic modeller forum, like the [[http://www.rcgroups.com|RCGroups]]. |
faq.1460735167.txt.gz (104466 views) ยท Last modified: 2016/04/15 08:46 by FDR
