get_started_with_deviationtx [2016/05/03 21:57] Arnold [Install deviation] |
Line 9: | Line 10: | ||
Line 16: | Line 17: | ||
Line 27: | Line 28: | ||
Line 44: | Line 45: | ||
Line 58: | Line 59: | ||
- | If you haven't found an answer for your particular question, just ask away in the [[http://www.deviationtx.com/forum|Forum]]. However when you start a new topic, please select a category appropriate to your question! And only pick one to start with. Creating two threads just makes things confusing, and if it's in the wrong place that can be dealt with later. | + | The [[Programming guides|Tutorials and How To's]] can also be helpful. |
get_started_with_deviationtx.txt (37282 views) · Last modified: 2020/01/31 12:43 by laurent_martin
