hardware:devo8
hardware:devo8 [2016/04/15 09:23] PhracturedBlue created |
hardware:devo8 [2016/04/15 14:42] FDR |
Line 11: | Line 12: | ||
+ | **TL:** Trim Left | ||
+ | **TR:** Trim Right | ||
+ | **TU:** Trim Up | ||
+ | **TD:** Trim down | ||
hardware/devo8.txt (101162 views) · Last modified: 2016/04/20 07:26 by PhracturedBlue
