hardware:jumper_t12
hardware:jumper_t12 [2019/01/25 21:31] PhracturedBlue created |
hardware:jumper_t12 [2019/04/26 15:22] goebish [FCC Report] |
- | ===WIP: This is currently just a copy of the X9D page=== | ||
===== Jumper T12 Hardware Connections ===== | ===== Jumper T12 Hardware Connections ===== | ||
The following documents the hardware inside the Jumper T12 transmitter | The following documents the hardware inside the Jumper T12 transmitter | ||
Line 6: | Line 5: | ||
* LCD Display: 128x64 B&W display | * LCD Display: 128x64 B&W display | ||
- | * Digital volume control: CAT5137 on i2c BUS | ||
Line 14: | Line 13: | ||
- | |0 |Stick RV | | + | |0 (ADC_IN_0) |Stick RV | |
- | |1 |Stick RH | | + | |1 (ADC_IN_1) |Stick RH | |
- | |2 |Stick LH | | + | |2 (ADC_IN_2) |Stick LV | |
- | |3 |Stick LV | | + | |3 (ADC_IN_3) |Stick LH | |
- | |4 |Audio DAC (???) | | + | |4 |Audio Out | |
- | |5 |Switch C- | | + | |5 |Switch B_H | |
- | |6 |POT L (Aux2) | | + | |6 (ADC_IN_6) |AUX5 POT | |
- | |7 |PPM for external module | | + | |7 |Ext Module TX | |
- | |*8 |Trainer plug detect | | + | |8 |Trainer plug detect | |
|9 |USB Vin | | |9 |USB Vin | | ||
- | |10 |PPM for FrSky Module | | + | |10 |Int Module TX | |
|11 |USB Data- | | |11 |USB Data- | | ||
|12 |USB Data+ | | |12 |USB Data+ | | ||
- | |13 |SWDIO (Pads on P12.2) | | + | |13 |SWDIO (???) | |
- | |14 |SWCLK (Pads on P12.3) | | + | |14 |PCBREV | |
- | |*15 (SPI3 CS) |LCD C/S | | + | |15 (SPI3 CS) |LCD C/S | |
- | |0 |POT R (Aux3) | | + | |0 (ADC_IN_8) |AUX4 POT | |
- | |1 |Switch D- | | + | |1 |LED Green | |
- | |2 |??? | | + | |2 |S.Port Update PWR | |
- | |3 |Switch E- | | + | |3 |??? | |
- | |4 |Switch E+ | | + | |4 |??? | |
- | |5 |Switch A+ | | + | |5 |??? | |
- | |6 (I2C SCL) |EEPROM SCL(???) | | + | |6 (I2C SCL) |EEPROM SCL | |
- | |7 (I2C SDA) |EEPROM SDA(???) | | + | |7 (I2C SDA) |EEPROM SDA | |
- | |8 |Backlight PWM | | + | |8 |Haptic | |
- | |9 (I2C WP) |EEPROM WP(???) | | + | |9 (I2C WP) |EEPROM WP | |
- | |10 |UART3 Tx | | + | |10 (USART_3_TX) |Bluetooth Tx | |
- | |11 |UART3 Rx | | + | |11 (USART_3_RX) |Bluetooth Rx | |
- | |12 (SPI2 CS) |SD Card ChipSelect | | + | |12 (SPI2 CS) |SD Card Enable | |
|14 (SPI2 MISO) |SD Card MISO | | |14 (SPI2 MISO) |SD Card MISO | | ||
Line 52: | Line 51: | ||
- | |0 |Voltage detect | | + | |0 (ADC_IN_10) |Voltage detect | |
- | |*2 |Buttom 'Trim RVU' | | + | |2 |Button 'Trim RVU' | |
- | |*3 |Buttom 'Trim RVD' | | + | |3 |Button 'Trim RVD' | |
- | |4 |Slider L (Aux4) | | + | |4 |LED Blue | |
- | |5 |Slider R (Aux5) | | + | |5 |LED Red | |
- | |6 |Power LED | | + | |6 |Int Module PWR | |
- | |7 |Heartbeat (???) | | + | |7 |Heartbeat | |
- | |*8 |Trainer PPM In | | + | |8 |Trainer PPM In | |
- | |*9 |Trainer PPM Out | | + | |9 |Trainer PPM Out | |
- | |*10 (SPI3 SCK) |I2S_Audio SCK(???) | | + | |10 (SPI3 SCK) |LCD SCK | |
- | |*11 |LCD A0 | | + | |11 |LCD A0 | |
- | |*12 (SPI3 SD) |I2S_Audio SD(???) | | + | |12 (SPI3 SD) |LCD MOSI | |
- | |13 |Buttom 'Trim RH +' | | + | |13 |??? | |
|14 |XTAL | | |14 |XTAL | | ||
|15 |XTAL | | |15 |XTAL | | ||
Line 71: | Line 70: | ||
- | |0 |Power shutdown | | + | |0 |Power on | |
- | |1 |Power switch postition | | + | |1 |Power button press | |
- | |*2 |Button 'Exit' | | + | |2 |Button 'Exit' | |
- | |*3 |Button 'Page' | | + | |3 |Button 'Page' | |
- | |4 |Sport Enable(???) | | + | |4 |Telemetry Dir | |
- | |5 |Sport Tx(???) | | + | |5 |Telemetry TX | |
- | |6 |Sport Rx(???) | | + | |6 |Telemetry RX | |
- | |*7 |Button 'Menu' | | + | |7 |Button 'Menu' | |
- | |8 |??? | | + | |8 |Ext Module Pwr | |
- | |10 |LCD MOSI | | + | |10 |??? | |
- | |11 |LCD CLK | | + | |11 |Switch: C_L | |
- | |*12 |LCD RST | | + | |12 |LCD RST | |
- | |13 |LCD A0 | | + | |13 |LCD Backlight | |
- | |14 |LCD NCS | | + | |14 |Switch H | |
- | |*15 |Trim LHL | | + | |15 |Button 'Trim LHL' | |
- | |0 |Switch A- | | + | |0 |Switch C_H | |
- | |1 |Switch B+ | | + | |1 |Switch D_L | |
- | |2 |Switch B- | | + | |2 |Switch D_H | |
- | |*3 |Button 'Trim RHL' | | + | |3 |Button 'Trim RHL' | |
- | |*4 |Button 'Trim RHR' | | + | |4 |Button 'Trim RHR' | |
- | |*5 |Button 'Trim LVU' | | + | |5 |Button 'Trim LVU' | |
- | |*6 |Button 'Trim LVD' | | + | |6 |Button 'Trim LVD' | |
- | |7 |Switch D+ | | + | |7 |Switch A_L | |
- | |8 |Switch G- | | + | |8 |??? | |
- | |*9 |Button 'Plus' | | + | |9 |Button 'Plus' | |
- | |*10 |Button 'Enter' | | + | |10 |Button 'Enter' | |
- | |*11 |Button 'Minus' | | + | |11 |Button 'Minus' | |
- | |12 |Button 'Minus' | | + | |12 |Bluetooth Enable | |
- | |13 |Switch H | | + | |13 |Switch A_H | |
|14 |Switch F | | |14 |Switch F | | ||
- | |15 |Switch C+ | | + | |15 |Switch B_L | |
- | ==== Pad P12 ==== | + | |
- | ^Pin ^Description ^ | + | |
- | |1 |3.3V | | + | |
- | |2 |PA13 | | + | |
- | |3 |PA14 | | + | |
- | |4 |GND | | + | |
Line 124: | Line 116: | ||
hardware/jumper_t12.txt (71621 views) · Last modified: 2019/04/26 15:22 by goebish
