hardware:radiolink_at9
hardware:radiolink_at9 [2016/04/20 07:04] PhracturedBlue |
hardware:radiolink_at9 [2016/04/30 20:34] PhracturedBlue |
Line 4: | Line 4: | ||
* MCU: [[http://www.st.com/web/catalog/mmc/FM141/SC1169/SS1031/LN1565/PF164491|STM32F103VCT6]] 512kB Flash, 64kB RAM 100pin package | * MCU: [[http://www.st.com/web/catalog/mmc/FM141/SC1169/SS1031/LN1565/PF164491|STM32F103VCT6]] 512kB Flash, 64kB RAM 100pin package | ||
- | * EEPROM: [[http://pdf1.alldatasheet.com/datasheet-pdf/view/310964/ISSI/IS25C128A-2GLI/+2119J7VGRSpbKUtzpNzhKKEyZV+/datasheet.pdf|IS25C128A-2GLI]] 128K-bit SPI SERIAL EEPROM | + | * EEPROM: [[http://www.giantec-semi.com/upload/datasheet/GT24C128A_DS_Adv.pdf|GT24C128A]] 128K-bit I2C SERIAL EEPROM |
- | * LCD Driver: ILI9345? based 320x240x16color display | + | * LCD Driver: ILI9341 based 320x240x1bit display |
- | ==== STM32 Connections ==== | ||
- | ^Pin ^Desription ^ | ||
Line 83: | Line 81: | ||
- | |PE00 | DISP19 | Control | | | + | |PE00 | LCDRESx | Reset Pin for LCD | Reset is Active low | |
Line 95: | Line 93: | ||
+ | === FCC Report === | ||
+ | FCCID: [[https://www.fcc.gov/general/fcc-id-search-page| U2B RL039AT9]] | ||
hardware/radiolink_at9.txt (204706 views) ยท Last modified: 2019/02/27 05:21 by csujun
