hardware:radiolink_at9
hardware:radiolink_at9 [2016/04/30 20:34] PhracturedBlue |
hardware:radiolink_at9 [2016/04/30 21:09] PhracturedBlue |
Line 81: | Line 81: | ||
- | |PE00 | LCDRESx | Reset Pin for LCD | Reset is Active low | | + | |PE00 | DISP19 | RESx ILI9341 Pin | Reset is Active low | |
|PE02 | BUZZER | | Transistor | | |PE02 | BUZZER | | Transistor | |
hardware/radiolink_at9.txt (187158 views) ยท Last modified: 2019/02/27 05:21 by csujun
