modulelist:multimod
modulelist:multimod [2016/04/14 19:06] PhracturedBlue created |
modulelist:multimod [2017/05/29 01:46] (current) mwm Change required version from "nightly" to 5.0.0 or later. |
| Line 2: | Line 2: | ||
| The MultiModule is a circuit-board + ATTiny AVR chip which can be used to control up to 4 modules on a Deviation Transmitter. | The MultiModule is a circuit-board + ATTiny AVR chip which can be used to control up to 4 modules on a Deviation Transmitter. | ||
| - | The MultiModule is only supported by the nightly-builds at the moment, and will not work with Deviation 4.0.1 or earlier. | + | The MultiModule requires Deviation 5.0.0 or later.. |
| *If installing a 'DEVO' CYRF6936 module into the MultiMod, the 5.0V pin must be connected between the MultiMod and the Transmitter, otherwise it can be left floating* | *If installing a 'DEVO' CYRF6936 module into the MultiMod, the 5.0V pin must be connected between the MultiMod and the Transmitter, otherwise it can be left floating* | ||
modulelist/multimod.txt (7139 views) ยท Last modified: 2017/05/29 01:46 by mwm
