modulelist
modulelist [2016/03/28 14:09] mwm created |
modulelist [2016/12/13 15:33] Arnold |
Line 15: | Line 16: | ||
- | | [[ModuleList#markdown-header-skyartec-httpwwwskyarteccomproductshowasparticleid1977|CC2500 Skyartec]] | 1 | 6 | 3 | 2 | 4 | 8 | Connect 5->10 and 7->9 **(*)** | | + | | [[modulelist:cc2500#skyartec|CC2500 Skyartec]] | 1 | 6 | 3 | 2 | 4 | 8 | Connect 5->10 and 7->9 **(*)** | |
- | | [CC2500 Aliexpress](ModuleList#markdown-header-aliexpress-httpwwwaliexpresscomitemcc2500-pa-lna-wireless-module-far-distance-2-4g359941652html) | 1 | 6 | 3 | 2 | 4 | 8 | Connect 5->10 and 7->9 **(*)** | + | | [[modulelist:cc2500#aliexpress|CC2500 Aliexpress]] | 1 | 6 | 3 | 2 | 4 | 8 | Connect 5->10 and 7->9 **(*)** |
- | | [XL2500](ModuleList#markdown-header-xl2500-ebay-httpwwwebaycomitm110983783515) | 2 | 1 | 5 | 7 | 6 | 4 | Connect 3->10 and 8->9 **(*)** | | + | | [[modulelist:cc2500#xl2500_ebay|XL2500]] | 2 | 1 | 5 | 7 | 6 | 4 | Connect 3->10 and 8->9 **(*)** | |
- | | [CC2500 NoPA](ModuleList#markdown-header-aliexpress-nopa-httpwwwaliexpresscomitem1-pcs-cc2500-wireless-module-small-size-2-4ghz-wireless-transceiver-module-free-shipping-dropshipping1566632579html) | 2 | 1 | 4 | 3 | 5 | 8 | | + | | [[modulelist:cc2500#aliexpress-nopa|CC2500 NoPA]] | 2 | 1 | 4 | 3 | 5 | 8 | |
- | | [CC2500 Small](ModuleList#markdown-header-small-nopa-httpwwwebaycomitm1-8-3-6v-cc2500-ic-wireless-rf-transceiver-2-4g-2400mhz-module-ism-spi-demo-code-280943872644) | 2 | 1 | 4 | 3 | 5 | 8 | | + | | [[modulelist:cc2500#small-nopa|CC2500 Small]] | 2 | 1 | 4 | 3 | 5 | 8 | |
- | | [NRF24L01-UFL](ModuleList#markdown-header-ufl-antenna-httpwwwebaycomitm400611170500) | 2 | 1 | 5 | 6 | 7 | 4 | Connect 3->2 | | + | | [[modulelist:nrf24l01#ufl_antenna|NRF24L01-UFL]] | 2 | 1 | 5 | 6 | 7 | 4 | Connect 3->2 | |
- | | [XL24L01-D03](ModuleList#markdown-header-xl24l01-httpwwwebaycomitm160763860120) | 2 | 1 | 5 | 6 | 7 | 4 | Connect 3->2 | | + | | [[modulelist:nrf24l01#xl24l01|XL24L01-D03]] | 2 | 1 | 5 | 6 | 7 | 4 | Connect 3->2 | |
- | | [XL7105-D03](ModuleList#markdown-header-xl7105-d03-httpwwwebaycomitm181091377178) | 1 | 3 | 4 | 5 | -- | 2 | Connect 6->9 and 7->8 **(*)** | | + | | [[modulelist:a7105#xl7105-d03|XL7105-D03]] | 1 | 3 | 4 | 5 | -- | 2 | Connect 6->9 and 7->8 **(*)** | |
- | | [A7105-V911](ModuleList#markdown-header-v911-v911moduleremoval) | 6 | 5 | 2 | 3 | -- | 1 | | + | | [[modulelist:a7105#a7105-v911|A7105-V911]] | 6 | 5 | 2 | 3 | -- | 1 | |
- | | [A7105-Xeida](ModuleList#markdown-header-xeida-similar-to-v911moduleremovalxeida) | 6 | 5 | 2 | 3 | -- | 1 | | + | | [[modulelist:a7105#a7105-xeida|A7105-Xeida]] | 6 | 5 | 2 | 3 | -- | 1 | |
- | | [XL7105-SY](ModuleList#markdown-header-xl7105-sy-httpwwwebaycomitm171154521980) | 2 | 3 | 6 | 7 | -- | 5 | | + | | [[modulelist:a7105#xl7105-sy|XL7105-SY]] | 2 | 3 | 6 | 7 | -- | 5 | |
- | | [CYRF6936-DEVO](ModuleList#markdown-header-devo-httpwwwehirobocomwalkera-wk-devo-s-mod-devo-8-or-12-to-devo-8s-or-12s-upgrade-modulehtml) | 1(5V) | 5 | 4 | 8 | 10 | 2 | Connect 9->5 | | + | | [[modulelist:cyrf6936#devo|CYRF6936-DEVO]] | 1(5V) | 5 | 4 | 8 | 10 | 2 | Connect 9->5 | |
- | | [CYRF6936-AWA24S](ModuleList#markdown-header-awa24s-httpwwwdigikeycomproduct-detailenawa24s748-1003-nd1687150) | 2 | 1 | 7 | 5 | 8 | 6 | Connect 10->11->2 and 3->12 **(*)** | | + | | [[modulelist:cyrf6936#awa24s|CYRF6936-AWA24S]] | 2 | 1 | 7 | 5 | 8 | 6 | Connect 10->11->2 and 3->12 **(*)** | |
- | | [CYRF6936-BuyChina](ModuleList#markdown-header-buychina-httpwwwbuychinacomitems2-4g-module-cyrf6936-pa-lna-module-cyrf6936-20dbm-module-uuruunslkhi) | 10 | 9 | 2 | 4 | 5 | 1 | Connect 7->11 and 8->12 **(*)** | | + | | [[modulelist:cyrf6936#buychina|CYRF6936-BuyChina]] | 10 | 9 | 2 | 4 | 5 | 1 | Connect 7->11 and 8->12 **(*)** | |
- | | [MultMod v1.2/1.3](ModuleList#markdown-header-multimod-v12v13-httposhparkcomshared_projectsdf3iwl1j) | 2 | 7 | 6 | 4 | 5 | 8 | **See Notes Below** | | + | | [[modulelist:multimod#multimod_v12_v13|MultMod v1.2/1.3]] | 2 | 7 | 6 | 4 | 5 | 8 | **See Notes On Module Page** | |
- | | [MultiMod v1.4](ModuleList#markdown-header-multimod-v14) | 2 | 7 | 6 | 4 | 5 | 8 | **See Notes Below** | | + | | [[modulelist:multimod#multimod_v14|MultiMod v1.4]] | 2 | 7 | 6 | 4 | 5 | 8 | **See Notes On Module Page** | |
- | + | | [[modulelist:3-in-1 module#3-in-1|3-in-1 Module]] | X | X | X | X | X | X | **See Notes On Module Page** | | |
- | ===== CC2500 ===== | + | | [[modulelist:4-in-1 module#4-in-1|4-in-1 Module]] | 1 | 6 | 4 | 8 | 10 | 2 | **See Notes On Module Page** | |
- | The CC2500 module is necessary to support the Skyartec and Frsky protocols. It is possible to scavenge this module from a Skyartec transmitter or to purchase it standalone. When searching ebay or aliexpress, searching for ‘CC2500 PA’ will often return reasonable results | + | |
- | The small CC2500 is very small - about 17x12 mm. It has no PA and no LNA, It supports some telemetry, as I get voltage but no RSSI. A quick range test showed no problems out to over 100 meters using a FrSky D4R-II, at which point I ran out of room. | + | |
- | ==== Skyartec : http://www.skyartec.com/ProductShow.asp?ArticleID=1977 ==== | + | |
- | The Skyartec module can also be salvaged from a Skyartec Transmitter: [[SkyartecModuleRemoval]] | + | |
- | {{https://bitbucket.org/repo/Ag6rxe/images/2270016736-CC2500-Skyartec.jpg}} | + | |
- | *4.0.1 and earlier: Connect 9->3.3v and 10->GND. Leave 5 and 7 floating | + | |
- | After 4.0.1, connect 5->10 and 7->9. | + | |
- | ### Aliexpress : http://www.aliexpress.com/item/CC2500-PA-LNA-wireless-module-far-distance-2-4G/359941652.html ### | + | |
- | ![CC2500-Wide.jpg](https://bitbucket.org/repo/Ag6rxe/images/143228236-CC2500-Wide.jpg) | + | |
- | ### XL2500 (Ebay) : http://www.ebay.com/itm/110983783515 ### | + | |
- | ![491059430-XL2500-D03.jpg](https://bitbucket.org/repo/Ag6rxe/images/249670922-491059430-XL2500-D03.jpg) | + | |
- | *4.0.1 and earlier: Connect 9->GND and 10->3.3v. Leave 3 and 8 floating | + | |
- | After 4.0.1, connect 3->10 and 8->9 | + | |
- | ### Aliexpress-NoPA : http://www.aliexpress.com/item/1-pcs-CC2500-Wireless-Module-Small-Size-2-4GHz-Wireless-Transceiver-Module-Free-Shipping-Dropshipping/1566632579.html ### | + | |
- | ![CC2500-NoPA.jpg](https://bitbucket.org/repo/Ag6rxe/images/1241255784-CC2500-NoPA.jpg) | + | |
- | ### Small-NoPA : http://www.ebay.com/itm/1-8-3-6V-CC2500-IC-Wireless-RF-Transceiver-2-4G-2400MHZ-Module-ISM-SPI-Demo-Code-/280943872644 ### | + | |
- | ![SmallCC2500.jpg](https://bitbucket.org/repo/Ag6rxe/images/3497153945-SmallCC2500.jpg) | + | |
- | ## NRF24L01 ## | + | |
- | ### U.FL Antenna : http://www.ebay.com/itm/400611170500 ### | + | |
- | ![NRF24L01-PA.jpg](https://bitbucket.org/repo/Ag6rxe/images/216789527-NRF24L01-PA.jpg) | + | |
- | ### XL24L01 : http://www.ebay.com/itm/160763860120 ### | + | |
- | ![XL24L01-D03.jpg](https://bitbucket.org/repo/Ag6rxe/images/2931607708-XL24L01-D03.jpg) | + | |
- | ## A7105 ## | + | |
- | The A7105 module is necessary to support the Flysky protocol (also used by WLToys V911, V9x9, and Xeida 99x8) and the Hubsan X4 protocol. | + | |
- | It is possible to scavenge this module from a WLToys Flysky protocol transmitter, an Xeida 99x8 transmitter, or to purchase it standalone. | + | |
- | The XL7105-D03 is an A7105 transceiver with an integrated power-amp providing 17dBm of output power. It can be obtained from Ebay or Aliexpress. Typical search term: ‘A7105-500m’ | + | |
- | I have run a range test comparing the XL7105-D03 and V911-Tx modules. In both cases I set the Tx on the ground, the antenna was inside the Tx and was bound to the V911. I then walked until the light on the V911 would flash intermittently. The path was line-of sight, but along the edge of the woods, so not exactly a wide open field. | + | |
- | Using the V911 Module: range = 600ft | + | |
- | Using the aliexpress module: range = 650ft | + | |
- | The XL7105-D03 is rated at 500M, but at least with my setup, I didn’t see any where near that distance. | + | |
- | The Xeida module is similar to the WLToys modules, except that it has an antenna on the board, instead of a small attached antenna. A range test similar to the XL7105-D03 and V911-Tx modules (different location, different V911, different Tx) gave a range of about 100 ft. | + | |
- | ### XL7105-D03 : http://www.ebay.com/itm/181091377178 ### | + | |
- | ![XL7105-D03.jpg](https://bitbucket.org/repo/Ag6rxe/images/2956021120-XL7105-D03.jpg) | + | |
- | *4.0.1 and earlier: Connect 8->GND and 9->3.3V. Leave 6 and 7 floating | + | |
- | After 4.0.1, connect 6->9 and 7->8 | + | |
- | ### V911 : [[V911ModuleRemoval]] ### | + | |
- | ![A7105-V911.jpg](https://bitbucket.org/repo/Ag6rxe/images/454457668-A7105-V911.jpg) | + | |
- | ### Xeida : Similar to [[V911ModuleRemoval]][xeida] ### | + | |
- | ![CC-958TG.png](https://bitbucket.org/repo/Ag6rxe/images/1750415647-CC-958TG.png) | + | |
- | ### XL7105-SY : http://www.ebay.com/itm/171154521980 ### | + | |
- | ![XL7105-SY.jpg](https://bitbucket.org/repo/Ag6rxe/images/312503663-XL7105-SY.jpg) | + | |
- | ## CYRF6936 ## | + | |
- | ### DEVO : http://www.ehirobo.com/walkera-wk-devo-s-mod-devo-8-or-12-to-devo-8s-or-12s-upgrade-module.html ### | + | |
- | ![CYRF6936-DEVO.jpg](https://bitbucket.org/repo/Ag6rxe/images/3966736255-CYRF6936-DEVO.jpg) | + | |
- | ### AWA24S : http://www.digikey.com/product-detail/en/AWA24S/748-1003-ND/1687150 ### | + | |
- | ![AWA24S.jpg](https://bitbucket.org/repo/Ag6rxe/images/3141475197-AWA24S.jpg) | + | |
- | *4.0.1 and earlier: Connect 10->3.3v, 11->3.3v, 12->GND. Leave 3 and 4 floating | + | |
- | After 4.0.1, connect 10->11->2 and 3->12 | + | |
- | ### BuyChina : http://www.buychina.com/items/2-4g-module-cyrf6936-pa-lna-module-cyrf6936-20dbm-module-uuruunslkhi ### | + | |
- | ![CYRF6936-BuyChina.jpg](https://bitbucket.org/repo/Ag6rxe/images/3717190240-CYRF6936-BuyChina.jpg) | + | |
- | *4.0.1 and earlier: Connect 11->GND and 12->3.3V. Leave 3, 6, 7, and 8 floating | + | |
- | After 4.0.1, connect 7->11 and 8->12 | + | |
- | ## MultiModule ## | + | |
- | The MultiModule is a circuit-board + ATTiny AVR chip which can be used to control up to 4 modules on a Deviation Transmitter. | + | |
- | The MultiModule is only supported by the nightly-builds at the moment, and will not work with Deviation 4.0.1 or earlier. | + | |
- | *If installing a 'DEVO' CYRF6936 module into the MultiMod, the 5.0V pin must be connected between the MultiMod and the Transmitter, otherwise it can be left floating* | + | |
- | *The Reset pin only needs to be connected if you plan to program the AVR via your transmitter. In this case, connect the 'Reset' pin to the 'TCK' pin of the Devo transmitter* | + | |
- | ### MultiMod v1.2/v1.3 : http://oshpark.com/shared_projects/Df3iWl1J ### | + | |
- | ***NOTE: Pin ordering is reversed on this module compared to all other transceiver modules*** | + | |
- | ![MultiModv1.3.jpg](https://bitbucket.org/repo/Ag6rxe/images/3707762924-MultiModv1.3.jpg) | + | |
- | ### MultiMod v1.4 : ### | + | |
- | ![MultiModv1.4.jpg](https://bitbucket.org/repo/Ag6rxe/images/1149863121-MultiModv1.4.jpg) | + | |
modulelist.txt (19261 views) · Last modified: 2016/12/13 15:33 by Arnold
