release_notes:5.0.0
release_notes:5.0.0 [2016/04/27 06:16] PhracturedBlue |
release_notes:5.0.0 [2016/05/25 09:56] Arnold [Minor Features / Bug Fixes] |
* Follow the instructions in the [[ http://www.deviationtx.com/user-manual | User Manual ]] that applies to your transmitter | * Follow the instructions in the [[ http://www.deviationtx.com/user-manual | User Manual ]] that applies to your transmitter | ||
+ | * Fix date displays | ||
+ | * Protocol fixes | ||
- | + | * SymaX | |
+ | * YD717 now supports Sky Walker 1306 | ||
+ | * H377 protocol | ||
+ | * HM380 protocol | ||
+ | * KN (V977) protocol | ||
+ | * ESky150 protocol | ||
+ | * Bluefly HP100 | ||
+ | * CX10 protocol | ||
+ | * Joysway protocol | ||
+ | * Hontai protocol | ||
+ | * FY326 protocol | ||
+ | * MJXq protocol | ||
+ | * H8_3d protocol | ||
release_notes/5.0.0.txt (32735 views) · Last modified: 2017/05/17 08:03 by Texacate
