release_notes:5.0.0
release_notes:5.0.0 [2016/04/30 10:02] PhracturedBlue |
release_notes:5.0.0 [2016/05/25 09:56] Arnold [Minor Features / Bug Fixes] |
Line 13: | Line 13: | ||
* Allow reordering mixers on Devo7e/10 | * Allow reordering mixers on Devo7e/10 | ||
* Reworked telemetry to have different displays for different protocols | * Reworked telemetry to have different displays for different protocols | ||
- | ==== Minor Features ==== | + | ==== Minor Features / Bug Fixes ==== |
* Support hardware modification to add extra switches to the devo7e | * Support hardware modification to add extra switches to the devo7e | ||
* Support hardware modification to add vibration for Devo6/8 | * Support hardware modification to add vibration for Devo6/8 | ||
Line 24: | Line 26: | ||
* Fix power output contol for CC2500 protocols | * Fix power output contol for CC2500 protocols | ||
* Fix date displays | * Fix date displays | ||
Line 29: | Line 40: | ||
- | * Show dialog for WK* protocols until biding is complete | + | * DSM2/X - support extended telemetry info |
- | * Support up to 12 channels on USBHID | + | * DSM2/X - fix GPS heading units |
* V202 - Support bind on power-up | * V202 - Support bind on power-up | ||
==== New protocols ==== | ==== New protocols ==== | ||
Line 45: | Line 64: | ||
* HM380 protocol | * HM380 protocol | ||
* KN (V977) protocol | * KN (V977) protocol | ||
+ | * ESky150 protocol | ||
+ | * Bluefly HP100 | ||
+ | * CX10 protocol | ||
+ | * Joysway protocol | ||
+ | * Hontai protocol | ||
+ | * FY326 protocol | ||
+ | * MJXq protocol | ||
+ | * H8_3d protocol | ||
release_notes/5.0.0.txt (27951 views) · Last modified: 2017/05/17 08:03 by Texacate
