release_notes:5.0.0
release_notes:5.0.0 [2016/04/30 10:47] PhracturedBlue |
release_notes:5.0.0 [2017/05/17 08:03] Texacate added the date 5.0.0 was released |
- | ** NOTE: Deviation 5.0.0 has not been released yet. There release notes are a work-in progress** | + | Version 5.0.0 was released on 2016-04-30 |
Line 29: | Line 31: | ||
* Improve scrolling on many of the GUI screens | * Improve scrolling on many of the GUI screens | ||
* Support viewing virtual channels on Channel-test page | * Support viewing virtual channels on Channel-test page | ||
- | * Telemetry alars are moe prominent | + | * Telemetry alarms are more prominent |
* Properly display PPMIN on main page | * Properly display PPMIN on main page | ||
* Add debug log display option | * Add debug log display option | ||
* Support newer Devo12S (with Rev2 Epson LCD driver) | * Support newer Devo12S (with Rev2 Epson LCD driver) | ||
* Fix channel mapping when loading templates | * Fix channel mapping when loading templates | ||
- | * Remove hardcoded fonts to improve themability | + | * Remove hardcoded fonts to improve theme-ability |
Line 40: | Line 42: | ||
Line 76: | Line 78: | ||
release_notes/5.0.0.txt (27935 views) · Last modified: 2017/05/17 08:03 by Texacate
