start [2016/04/16 15:00] Sero [Hardware modifications] |
start [2018/09/11 10:44] mangmeephol Pairoj |
+ | * Read the manual | ||
- | [[Transmitter Switches]] | + | ---- |
+ | *[[hardware:devo8|Devo 8] | ||
- | Here is a list of model files that have been submitted by the DeviationTx forum users: [[model_config]] | + | [[voiceoutput|Adding module for voice output]] |
start.txt (69267 views) · Last modified: 2020/08/18 02:45 by kestel
