start [2016/04/20 06:30] PhracturedBlue |
+ | * Read the manual | ||
- | [[transmiterswitches|Transmiter Switches]] | + | ---- |
- | ===== List of Example Model Configurations ===== | + | ---- |
- | Here is a [[model_config|list of model files]] that have been submitted by the DeviationTx forum users | + | |
- | ===== Development ===== | + | ===== Hardware & Modifications ===== |
- | Whether your interest is in buidling the code yourself, or understanding the hardware the Deviation runs on, you can find more information on our [[development]] page | + | Once you've got deviationTx installed and working, there are a number of modifications you can make to the hardware to make your transmitter more useful. They are documented here. |
+ | === Voice output === | ||
+ | ===== Development ===== | ||
+ | Whether your interest is in building the code yourself, or understanding the hardware the Deviation runs on, you can find more information on our [[development]] page |
start.1461159056.txt.gz (148527 views) · Last modified: 2016/04/20 06:30 by PhracturedBlue
