supported_models
supported_models [2019/03/12 21:00] Higgins |
supported_models [2019/03/12 21:06] (current) Higgins |
Line 285: | Line 285: | ||
|XK |[[https://www.deviationtx.com/forum/builds/5569-xk-k110-s-fhss-build-for-devo-7e-and-devo-10|K120]] |CP |[[modulelist:CC2500]] |[[protocol:S-FHSS]] |2016/04/13 | | | |XK |[[https://www.deviationtx.com/forum/builds/5569-xk-k110-s-fhss-build-for-devo-7e-and-devo-10|K120]] |CP |[[modulelist:CC2500]] |[[protocol:S-FHSS]] |2016/04/13 | | | ||
|XK |[[https://www.deviationtx.com/forum/builds/5569-xk-k110-s-fhss-build-for-devo-7e-and-devo-10|A600]] |Plane |[[modulelist:CC2500]] |[[protocol:S-FHSS]] |2016/04/13 | Would NOT bind to T8SG | | |XK |[[https://www.deviationtx.com/forum/builds/5569-xk-k110-s-fhss-build-for-devo-7e-and-devo-10|A600]] |Plane |[[modulelist:CC2500]] |[[protocol:S-FHSS]] |2016/04/13 | Would NOT bind to T8SG | | ||
- | |XK |A800 |Plane |[[modulelist:NRF24L01]] |[[protocol:KN]] |2019/03/13 | Select 'WLToys' in protocol options; Worked with T8SG; Thanks to Albert Kim [[https://youtu.be/WCdqvSzSxdg]] | | + | |XK |A800 |Plane |[[modulelist:NRF24L01]] |[[protocol:KN]] |2019/03/13 | Select 'WLToys' in protocol options; Worked with T8SG; Thanks to Albert Kim [[https://youtu.be/WCdqvSzSxdg?t=779]] | |
|XK |[[https://www.deviationtx.com/forum/builds/5569-xk-k110-s-fhss-build-for-devo-7e-and-devo-10?start=80#47690|X100]] |Quad |[[modulelist:CC2500]] |[[protocol:S-FHSS]] |2016/05/04 | | | |XK |[[https://www.deviationtx.com/forum/builds/5569-xk-k110-s-fhss-build-for-devo-7e-and-devo-10?start=80#47690|X100]] |Quad |[[modulelist:CC2500]] |[[protocol:S-FHSS]] |2016/05/04 | | | ||
|XK |[[http://www.rcgroups.com/forums/showthread.php?t=2536068|X250]] |Quad |[[modulelist:NRF24L01]] |[[protocol:V202]] |2016/01/31 | also known as Revell Quadrotox | | |XK |[[http://www.rcgroups.com/forums/showthread.php?t=2536068|X250]] |Quad |[[modulelist:NRF24L01]] |[[protocol:V202]] |2016/01/31 | also known as Revell Quadrotox | |
supported_models.txt (5737 views) ยท Last modified: 2019/03/12 21:06 by Higgins
