transmiterswitches
transmiterswitches [2016/07/05 13:09] Arnold [Switches available] |
Line 11: | Line 11: | ||
* **Modded**((There are [[http://www.deviationtx.com/forum/how-to/1436-add-two-switches-to-the-devo-7e?start=180|published hardware mods]] for the 7e to add two 2-way switches or a 3-way switch by just adding the connections. A more complicated mod makes it possible to add two three-way switches. These are supported in 5.0 and later)): \\ SW A0, SW A1, SW A2, SW B0, SW B1, SW B2 | * **Modded**((There are [[http://www.deviationtx.com/forum/how-to/1436-add-two-switches-to-the-devo-7e?start=180|published hardware mods]] for the 7e to add two 2-way switches or a 3-way switch by just adding the connections. A more complicated mod makes it possible to add two three-way switches. These are supported in 5.0 and later)): \\ SW A0, SW A1, SW A2, SW B0, SW B1, SW B2 | ||
+ | * **Devo F4**: | ||
transmiterswitches.txt (126651 views) · Last modified: 2017/05/21 12:03 by mwm
