transmitter:devo7e
transmitter:devo7e [2016/05/08 22:14] silpstream fix links |
transmitter:devo7e [2016/05/09 08:16] silpstream |
Line 29: | Line 31: | ||
Line 36: | Line 38: | ||
+ | == Disassembly == | ||
Line 45: | Line 55: | ||
- | This will modify the stock RF module for full range. It requires removal of the shield and bypassing of a diode (or resistor?) within module. Various methods for doing the bypass exists, so read through the tutorials and decide which you want to try. | + | This will modify the stock RF module for full range. It requires removal of the shield and bypassing of a diode within module. Various methods for doing the bypass exists, so read through the tutorials and decide which you want to try. |
- | *[[http://www.deviationtx.com/forum/3-feedback-questions/1439-removing-shield-and-diode-7e-for-better-reach|Removing shield and diode 7E for better reach]] on our fourm | + | *[[http://www.deviationtx.com/forum/3-feedback-questions/1439-removing-shield-and-diode-7e-for-better-reach|Removing shield and diode 7E for better reach]] by Mullson in our forum |
Line 61: | Line 71: | ||
+ | *[[http://www.deviationtx.com/forum/how-to/1436-add-two-switches-to-the-devo-7e|Add Two switches to the Devo 7E]] by cmpang in our forum | ||
+ | *[[http://www.deviationtx.com/forum/7-development/4442-extra-inputs-for-devo-tx-s?limitstart=0|Extra inputs for Devo Tx's]] by mwm in our forum | ||
+ | *[[http://www.deviationtx.com/forum/how-to/1455-battery-mod-devo7e|Battery Mod Devo 7E]] by Usjak in our forum | ||
+ | *[[http://www.deviationtx.com/forum/6-general-discussions/2910-devo-7e-a7105pa-range-mod-current-draw?start=20#24372|AMS1117 Replacement Regulator]] by Fernandez in our forum | ||
+ | *[[http://www.deviationtx.com/forum/6-general-discussions/5307-problem-with-overvolted-devo7e#43231|Pololu 3.3V Step-Up/Step-Down Voltage Regulator]] by Fernandez in our forum | ||
==== Other Devo 7E Resources ==== | ==== Other Devo 7E Resources ==== | ||
*[[http://www.hacksmods.com/tag/devo7e/|Devo 7E on hacksmods.com]] | *[[http://www.hacksmods.com/tag/devo7e/|Devo 7E on hacksmods.com]] |
transmitter/devo7e.txt (91060 views) · Last modified: 2019/02/22 15:39 by PhracturedBlue
