voiceoutput
voiceoutput [2018/05/12 09:26]
Moeder Update voice pack links
voiceoutput [2018/05/12 09:27] (current)
Moeder [Setting up the emulator for voice alerts]
Line 150: Line 150:
 Download and unzip the emulator package for your transmitter. ​ Download and unzip the emulator package for your transmitter. ​
-  - Download the //\mp3// folder and files and place the //\mp3// folder in the same folder with the exe.  The //\mp3// folder is included in the voice alerts zip file from [[https://​www.deviationtx.com/​downloads-new/​category/​1010-moeder-voice-packs|Test Builds/​[Moeder]voice_alerts]] or in the voice packs created by [[https://​moeder.pythonanywhere.com/​voicepacker/​default/​index|Deviation Voicepacker]].+  - Download the //\mp3// folder and files and place the //\mp3// folder in the same folder with the exe.  The //\mp3// folder is included in the voice alerts zip file from [[https://​www.deviationtx.com/​downloads-new/​category/​1010-moeder-voice-packs|Test Builds/​[Moeder]voice_packs]] or in the voice packs created by [[https://​moeder.pythonanywhere.com/​voicepacker/​default/​index|Deviation Voicepacker]].
   - Update the file system as you would update the TX file system:   - Update the file system as you would update the TX file system:
   * Make appropriate changes to the //​hardware.ini// ​   * Make appropriate changes to the //​hardware.ini// ​
   * Copy the //​voice.ini//​ to the //\media// folder   * Copy the //​voice.ini//​ to the //\media// folder
   * Edit each //​model.ini//​ to enable sounds or use the voice configuration menu (except devo7e, see above).   * Edit each //​model.ini//​ to enable sounds or use the voice configuration menu (except devo7e, see above).
voiceoutput.txt (150174 views) ยท Last modified: 2018/05/12 09:27 by Moeder
