modulelist:4-in-1_module [2016/12/01 14:23] Arnold |
- | Read post #55157 by Vlad_vy in the following thread for guidance on soldering to various Devo radios. | + | |
- | [[http://www.deviationtx.com/forum/7-development/5434-3in1-4in1-rf-module]] | + | |
modulelist/4-in-1_module.1480631029.txt.gz (17909 views) · Last modified: 2016/12/01 14:23 by Arnold
