modulelist:4-in-1_module [2016/12/11 13:42] Arnold |
- | Read post #55157 by Vlad_vy in the following thread for guidance on soldering to various Devo radios, along with the associated hardware.ini file settings. Here's the link: | ||
- | http://www.deviationtx.com/forum/7-development/5434-3in1-4in1-rf-module?start=160#55157 | ||
modulelist/4-in-1_module.1481492550.txt.gz (17602 views) · Last modified: 2016/12/11 13:42 by Arnold
