rf_module_installation
rf_module_installation [2016/04/15 12:05]
FDR [Adding External Modules to Your Deviation Transmitter]
rf_module_installation [2017/01/23 00:30] (current)
FDR link
Line 6: Line 6:
 ==== Modules ==== ==== Modules ====
 The following modules are supported by Deviation: [[modulelist:​a7105|A7105]],​ [[modulelist:​cc2500|CC2500]],​ [[modulelist:​nrf24l01|NRF24L01]],​ [[modulelist:​cyrf6936|CYRF6936]]. The following modules are supported by Deviation: [[modulelist:​a7105|A7105]],​ [[modulelist:​cc2500|CC2500]],​ [[modulelist:​nrf24l01|NRF24L01]],​ [[modulelist:​cyrf6936|CYRF6936]].
-Each can control a different set of modules/​receivers. A (mostly complete) list of models and the corresponding modules can be found in the [[https://​docs.google.com/​spreadsheet/​ccc?​key=0Any72n5Y9u-kdGFDeXhBY0I0ek1raTdEN21VTlBzTkE&​usp=sharing|Supported Models]] list. More information on each module as well as hints on where to obtain them can be found on the [[ModuleList]] page. Information how to build a "​universal module"​ can be found here [[Building the Multi-Module]].+Each can control a different set of modules/​receivers. A (mostly complete) list of models and the corresponding modules can be found in the [[supported_models|Supported Models]] list. More information on each module as well as hints on where to obtain them can be found on the [[ModuleList]] page. Information how to build a "​universal module"​ can be found here [[Building the Multi-Module]].
 ===== Module Installation ===== ===== Module Installation =====
 //NOTE: Read through this entire manual before starting work. Make sure you understand what is needed and how to do it. Also, this procedure will void the warranty of your Devo transmitter in the process of implementing this modification.//​ //NOTE: Read through this entire manual before starting work. Make sure you understand what is needed and how to do it. Also, this procedure will void the warranty of your Devo transmitter in the process of implementing this modification.//​
rf_module_installation.txt (138474 views) ยท Last modified: 2017/01/23 00:30 by FDR
