Deviation v5.0.0 build with latest protocols
28 Apr 2018 18:12 - 08 May 2018 06:41 #68908 by vlad_vy
Replied by vlad_vy on topic Deviation v5.0.0 build with latest protocols
Fresh emulator builds
(28.04.2018)
Files deleted, see below...
Last edit: 08 May 2018 06:41 by vlad_vy.
28 Apr 2018 18:18 - 08 May 2018 06:43 #68909 by vlad_vy
"Deviation v5.0.0 build with latest protocols" (based on v5.0.0 release core)
* Add mux type "beep".
You can add beeps to mixer. If input value equal to set value it will beep. Mux "beep" repeat input value without changes.
(28.04.2018)
Last edit: 08 May 2018 06:43 by vlad_vy.
28 Apr 2018 18:19 - 08 May 2018 06:45 #68910 by vlad_vy
I can't attach more than 10 files, and so XMS builds attached with separate message
(28.04.2018)
Last edit: 08 May 2018 06:45 by vlad_vy.
08 May 2018 06:42 - 04 Sep 2018 07:06 #69109 by vlad_vy
(08.05.2018)
Last edit: 04 Sep 2018 07:06 by vlad_vy.
08 May 2018 06:44 - 31 Jul 2018 05:16 #69110 by vlad_vy
* More reliable "beep" mux.
(08.05.2018)
Last edit: 31 Jul 2018 05:16 by vlad_vy.
08 May 2018 06:46 - 31 Jul 2018 05:19 #69111 by vlad_vy
(08.05.2018)
Last edit: 31 Jul 2018 05:19 by vlad_vy.
29 Jul 2018 08:16 #69980 by Hoodooguru
Replied by Hoodooguru on topic Deviation v5.0.0 build with latest protocols
vlad_vy wrote: "Deviation v5.0.0 build with latest protocols" (based on v5.0.0 release core)
* Fix Corona protocol, from hexfet
(25.03.2018)
Hello vlad,
I want to put Corona on my 8s, where do I find the correct file.
I already have devo8 v5.0.0 installed some time ago and also Banggood 4 in 1
Thank you and hexfet
29 Jul 2018 11:51 #69981 by Hoodooguru
ok, got it partly sorted, have Corona on tx but the is an asterix next to it???? what does this mean???
and how do I bind it????
tia
29 Jul 2018 13:06 #69982 by Hoodooguru
One step closer.
I thought I had all chips enabled but that was not the case, cc2500 now enabled, asterix is gone.
But I cannot bind Corona, using following method:
Corona DSSS V2 RXs: CR8D, CR6D and CR4D
To bind V2 RXs you must follow the below procedure (original):
press the bind button and power on the RX
launch a bind from Multi -> the RX will blink 2 times
turn off the RX and TX(=Multi)
turn on the RX first
turn on the TX(=Multi) second
wait for the bind to complete -> the RX will flash, stop and finally fix
wait some time (more than 30 sec) before turning off the RX
turn off/on the RX and test that it can reconnect instantly, if not repeat the bind procedure
Have done fine tuning thing, still no bind.
Also not able to bind Frsky which uses cc2500
Devo and spektrum protocols work, all connections to 4 in 1 are correct.
29 Jul 2018 13:59 #69983 by Hoodooguru
6936, 2401 and 7105 all tested and working.
Only 2500 protocols (Corona and Frsky) not working.
Anyone
29 Jul 2018 15:14 #69984 by Hoodooguru
Got Frsky to bind consistently.
But nothing I do will bind Corona.
  • BirdBarber
  • BirdBarber's Avatar
  • Hummingbird Assassin
30 Jul 2018 09:43 - 30 Jul 2018 09:52 #69992 by BirdBarber
Replied by BirdBarber on topic Deviation v5.0.0 build with latest protocols
Some CC2500 protocols need to have the frequency fine tuned.
Highlight the protocol and press ENT, then adjust Freq-Fine until it binds.
Try adjusting by steps of 10 to do it more quickly, it usually works.
Last edit: 30 Jul 2018 09:52 by BirdBarber.
30 Jul 2018 09:51 - 30 Jul 2018 09:54 #69993 by Hoodooguru
BirdBarber wrote: Some CC2500 protocols need to have the frequency fine tuned.
Try changing the value by 10 points at a time.
I said a couple of posts back that I already tried fine tuning.
Also, hexfet has posted that he fixed an error in the protocol and the fix will be in tonights nightly.
Last edit: 30 Jul 2018 09:54 by Hoodooguru.
30 Jul 2018 13:16 #69996 by Hoodooguru
fixed
31 Jul 2018 05:18 - 04 Sep 2018 06:57 #70002 by vlad_vy
* Fix corona protocol timing error, from hexfet
(31.07.2018)
Last edit: 04 Sep 2018 06:57 by vlad_vy.
31 Jul 2018 05:20 - 04 Sep 2018 06:57 #70003 by vlad_vy
(31.07.2018)
04 Sep 2018 07:02 - 06 Nov 2018 05:22 #70634 by vlad_vy
* Add protocol for MJX Bugs 3, 6, 8, from hexfet
The Bugs3 protocol is used to control MJX Bugs3 and Bugs8 aircraft.
To bind first choose the bugs3 protocol and click Bind. Then apply power to the aircraft.
The bind dialog will disappear if bind is successful. The aircraft's radio id is stored in the model
Fixed ID field. Do not change this value.
Channels used for controlling functions. Set channel value greater than zero to activate.
Arming is controlled by Channel 5
Lights are controlled by Channel 6
Flip is controlled by Channel 7
Camera is controlled by Channel 8
Video is controlled by Channel 9
Angle/acro controlled by Channel 10. Channel > 0 is angle mode.
Telemetry is supported for RSSI and voltage alarm. It uses the Frsky telemetry display with
signal strength reported in the RSSI field and battery voltage in VOLT1.
The bugs3 receiver only reports good/bad voltage. This is translated to VOLT1 values
of 8.4V for good and 6.0V for low voltage.
* Protocol Hubsan H122D / H123D, from goebish
Add extra channels to the Hubsan H501 sub-protocol.
Channel 12: H123D mode selection, 3-way: Sport 1 / Sport 2 / Acro
Channel 13: H122D flip mode
Forums thread: www.deviationtx.com/forum/model-configs/...2d-devo-10-model-ini
* Add Hitec protocol, from hexfet
Format protocol option selects between Optima and Minima receivers.
Freq fine protocol option available to adjust frequency.
Nine channels supported.
Telemetry supported using Frsky formatting.
* AFHDS 2A: Allow LQI output on Ch13 and Ch14, from goebish
Allow LQI output on Ch13 and Ch14, fixes #422
Add telemetry for 2nd temperature sensor, fixes #424
(04.09.2018)
Last edit: 06 Nov 2018 05:22 by vlad_vy.
04 Sep 2018 07:05 - 06 Nov 2018 05:21 #70635 by vlad_vy
(04.09.2018)
Last edit: 06 Nov 2018 05:21 by vlad_vy.
04 Sep 2018 07:07 - 06 Nov 2018 05:21 #70636 by vlad_vy
(04.09.2018)
04 Sep 2018 23:52 #70648 by wolfdale
Replied by wolfdale on topic Deviation v5.0.0 build with latest protocols
I tried the emulator for the devo 7e, and the "Fullspeed" option under DSM2/X protocol is present, but on my devo7e I can only enable Telemetry, and OrangeRX options. Is it a memory limitation of the radio? Thanks.
Time to create page: 0.092 seconds
